Results 1 to 18 of 18
  1. #1
    Archived Post from old forum
    Have just purchased new clio 172 as import and a couple of things have me puzzled - gear change indicator and alarm as neither get a mention in the handbook but thought were part of spec. Where is the gear change indicator? Do you have to do anything to get it to work? How do you tell if the car has an alarm fitted without breaking in to it! Can anyone enlighten me!
  2. #2
    Forum User
    Join Date
    Nov 2001
    Posts
    8,873
    Car
    Renault Laguna Coupe
    Theres a little green indicator in the bottom right of your dash - its meant to look like a gear lever. It will light up green just before the rev-limiter kicks in. Its not actually the optimum point at which to change gear as the engine gets a bit breathless above 6500rpm. It also lights up when you turn on the ignition for a few seconds. Your alarm has been fitted in the UK - you should have a separate leaflet for this.
    Welcome by the way!!
  3. #3
    shut the door with the window down a bit and lock it with the central locking! then wave your hands around inside it! wait for it to go off ...if it ever does!
    i didnt know gear change indicators were on the normal 172!
  4. #4
    Yep, gear change light is on normal 172!!! I only found out about it after reading this site. At first I thought it was a neutral light, the same as on a bike (doh!!!!).
    Not sure whether imports have an alarm. Just thought it was a cat 2 immobiliser. Ill have to try the above!!
  5. #5
  6. #6
    Join Date
    Mar 2002
    Location
    Manchester / Cheshire
    Posts
    7,878
    Car
    TT 225
    nice pic Matt!!!
  7. #7
    7100 RPM!?!?!?!?!
  8. #8
    7250
  9. #9
    Join Date
    Mar 2002
    Location
    Posts
    7,878
    Car
    TT 225
    yeah, and?
  10. #10
    lol, even better
  11. #11
    Forum User
    Join Date
    Dec 2001
    Location
    Northampton
    Posts
    1,441
    Car
    ICE'dberg MK2 172
    Imports dont come with alarms....its Renault UK that fit them prior to sending them to the dealers.
    So you havent got one unless you specified it with the importer.
  12. #12
    Join Date
    Jan 2003
    Location
    yorkshire
    Posts
    516
    Car
    Clio 200 FF
    Most 172s if not all with alarms have ultrasonic sensors on the windscreen pillars (look like small microphones)
  13. #13
    10566
  14. #14
    Thanks for clarifying the gear change indicator - I was looking at the rev counter rather than the speedo!
    Tried waving my arms around in the car etc. but looks as if there is no alarm - any recommendations as the Renault one seems expensive at £301.
  15. #15
    Join Date
    Nov 2002
    Location
    I <3 MAXIBON
    Posts
    6,912
    Car
    Revels Mum & Sister
    I wouldnt bother with a crap alarm mate. Your car is pricey.
    Go for a Clifford Arrow 3 with Single Zone Proxy sensor. Acts the same as the renault one but doesnt use Small "Microphones".
    Possibly better than the renault one. Or if you want to spend more. Go for the Concept 300 (Cat 1 alarm)
    Arrow 3 is about £275 (Fitted)
    Concept 300 is about £330 (Fitted)
    Well at Brother in laws company. Other places may charge different money. Go for a reputable dealer. As wrongly installed alarms are a never ending nightmare! All alarms have there faults though!
  16. #16
    Forum User
    Join Date
    Feb 2003
    Location
    Surrey
    Posts
    500
    Car
    RB5 & 172
    are the gear change indicators standard on all mkI 172s aswell?
    i thought they were but mine does not seem to have one, when i called the dealer they told me they were only ever on the early mkIs?
  17. #17
    Forum User
    Join Date
    Jun 2001
    Location
    Johannesburg
    Posts
    2,181
    Car
    2005 Audi A3 3.2 Quattro
    I have a June 2001 172 and mine has one
  18. #18
    Forum User
    Join Date
    Feb 2003
    Location
    Surrey
    Posts
    500
    Car
    RB5 & 172
    mine is march 2001 so mine must have one aswell then, guess ill be checking again at lunch.
    cheers.
Similar Threads
  1. Optimum gear - change indicator??? On a 182? I aint seen it?
    By chetannathwani in forum Clio Discussion
    Last Post: 29-11-2007, 23:21
  2. Is the 172 Mk2's Gear shift light an option ?
    By D1CKY in forum eBay, Pistonheads, & Autotrader
    Last Post: 11-11-2007, 19:43
  3. optimum gear change
    By delboy 182 in forum Clio Discussion
    Last Post: 20-07-2004, 20:41
  4. optimum gear change light
    By Locky in forum Clio Discussion
    Last Post: 12-10-2003, 20:57
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
Nobody has landed on this page from an internet search engine.
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
