Mk2 front and rear seats fitting removal
I had a quick search but I couldn't find anything, so here it goes:
1. Rear seats when you take the isofix bar out, then there are two torx screws for the rear seats, the back one is easy enough to get in and out with no problem. The front screw I've had to force my screwdriver into the seat to be able to get it to turn the screw but the screw is tight and the screwdriver ends up at an angle and slips. Does anyone have an easier way to do this or?
2. I understand the front seats are bolted from underneath the car, anyone got a picture of where the bolts are or a quick tip? And also what socket size they are?
Thanks in advance, Bambi.
Re: Mk2 front and rear seats fitting removal
The rear seats, you only need to take the back bolt out then they should just slide backwards.
And the fronts are 13mm nuts, with 4 bolts per seat 2 rubber grommets on the outside edge of the car that just pop off and the nuts are in there, then there is another 2 nuts near the heat shield of the exhaust.
Originally Posted by
Blacky950
Bambi
Hi i was just wondering did this work. are the bolts underneath the car??
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Visitors found this page by searching for:
fitting new seats clio mk2
change mk2 clio front seat
front seat removal on clio mk2
taking mark 2 clio seats out
cliosport.net how to remove seats out a clio mk2
clio mk2 front seats removal
mk2 front seat removal
how do you remove front seat of a clio mk2
renault clio front seat removal
bambi from clio
clio mk 2 front seat problems
remove clio front seat mk2
where are the front seat bolts for a renault clio
mk2 clio front seat removal
removing mk2 clio front seats
removing mk2 front seats
site:cliosport.net will other seats fit my clio
how to remove clio back seats
how to remove mk2 clio front seats
Powered by
vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules:
Sphinx-based search
