Results 1 to 3 of 3
  1. #1
    White/Blue smoke pouring out of my exhaust!
    Hey,
    I have a 51 plate clio dci 1.5 65 and i've had countless problems with it but despite the problems i love it! i've searched through loads of forums and some of the clio drivers have the same problem as i have now but none seem to have fixed it, does anyone have any idea what the problem might be? the smoke tends to pour out in first and second gear and stand still when the car has been running a while. i have also noticed that the engine itself tends to shake the chassis more than it used to. i understand that white/blue smoke indicates there is something wrong with a water/oil leak possibly but cannot see anything visible that doesn't look in place. i have also lowered the car and put a k&n air filter on, could that affect it?
    Any replies or advice would be much appreciated!
    Lewis
  2. #2
    Join Date
    Oct 2011
    Location
    Southend-on-Sea
    Posts
    89
    Car
    320td Daily XR2t Toy
    Blue white smoke is oil being burnt could be number of things. piston rings are dead and oil blowing past easy way to tell is to take the oil filler cap off and see if there is a lot of blow back. Could be dead turbo seal if you have a turbo diesel. Tired valve seals can give smoke but usual not bad. Could have over filled the oil not good! As it would do damage. Could be a damaged breather pushing a lot of oil vapour into the engine.
    Start with a compressor tester or taking the oil cap off and see if thereis a lot of blow back rule out worst case the rings.
  3. #3
    Join Date
    Apr 2011
    Location
    Sunderland
    Posts
    757
    Re: White/Blue smoke pouring out of my exhaust!
    Get yourself over to www.cliodci.net
    Does the engine have high mileage? If it does then the first thing to check is the compression on the engine as said. Its possible that the engine is burning a little oil on start up, possibly from worn valve stem seals.
    Its also possible that the glow plugs are not working as good as they would from new, so when you crank the engine compression builds in the sump and you have a little oil carried over into the compression camber.
    Try adding Redex for Diesel to your fuel to clean up any carbon that may have built up on the injector heads etc.
    Keep an eye on the level of the oil, if it starts to go down, then its probably time to consider further investigations.
    If not, then don't worry about it as most diesel's are a little dirty on start up.
Similar Threads
  1. Blue smoke from exhaust HELP?
    By TEE-2012 in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 01-07-2012, 23:12
  2. Replies: 0
    Last Post: 05-04-2009, 18:25
  3. blue smoke coming out of my exhaust
    By Adam w in forum Faults, Problems & Solutions
    Last Post: 08-01-2009, 12:30
  4. ARGH! WHITE smoke is POURING out of my dci!!! Help!!
    By Sparky1983 in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 21-11-2008, 20:22
  5. blue smoke from exhaust?
    By Dave138 in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 09-04-2006, 19:24
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
1.5 dci white smoke starting
1.5 dci smoking
my clio sport is smoking
why is my engine pouring out blue smoke
smoke in first and second gear
blue smoke - renault scenic diesel
put redex in dci renault clio blowing smoke from exhaust
clio dci smoke from oil checker
1.5dci smoke starting
car blowing blue smoke from exhaust when 1st gear
blue smoke from exhaust in first and second gear
car is pouring out smoke from exhaust help
04 renault scenic 1.5 turbo diesel a lot of white smoke
renault scenic 1.5 dci running lumpy and blue smoke from exhaust
renault scenic 1.5 dci smoking and pouring oil from exhaust
site:cliosport.net smoke 2nd gear
clio 1.5 dci smoking
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
