Page 1 of 2 1 2 LastLast
Results 1 to 20 of 22
Thread: Coolant Flush
  1. #1
    Forum User
    Join Date
    Mar 2004
    Location
    West Midlands
    Posts
    9,205
    Car
    MK1 Clio RTT
    Coolant Flush
    ok so im gonna be getting some coolant monday and i wanna do a flush of the system. never done one before but i wanna give it a go.
    im scared of removing the hoses on my radiator as they look a bit on the rusty side and im guessing they will split if i so much as look at them with a spanner, is there any other way i can get the coolant out of the rad without taking the hoses off from down there or am i just gonna have to go for it
    when the coolants emptied and the hose is back on, do i fill the radiator up and then the header tank? do i take a top hose off the radiator and use a funnel to fill the rad? then top up the tank when the hose is back on or does it just all go into the header tank?
    do i keep the cap off the header tank for a while til all the air bubbles stop coming to the surface, then put it on and bring upto temp, let it cool, then check the coolant level again, topping if i need to? anything else i should know or should do?
    cheers
  2. #2
    Join Date
    Mar 2011
    Location
    Banbury
    Posts
    388
    Car
    Renault Clio 182
    Re: Coolant Flush
    You will need to drop the bottom hose, What car are you doing it on?
  3. #3
    Forum User
    Join Date
    Mar 2004
    Location
    West Midlands
    Posts
    9,205
    Car
    MK1 Clio RTT
    Re: Coolant Flush
    mk1 clio, gtt engine but i think its running the clio rad, could be wrong though
  4. #4
    Forum User
    Join Date
    Mar 2004
    Location
    West Midlands
    Posts
    9,205
    Car
    MK1 Clio RTT
    Re: Coolant Flush
    will there definatly be a rubber hose on the bottom as i had a quick look yesterday but didnt see one, could only see metal pipework going in half way down and a top rubber hose
  5. #5
    Join Date
    Mar 2011
    Location
    Banbury
    Posts
    388
    Car
    Renault Clio 182
    Re: Coolant Flush
    is there a rad cap on the radiator if so fill the radiator once flushed ect do you have an expansion tank with markings? you may also need to bleed it unless this can can leave the expansion tank lid of and let it self bleed
  6. #6
    Forum User
    Join Date
    Mar 2004
    Location
    West Midlands
    Posts
    9,205
    Car
    MK1 Clio RTT
    Re: Coolant Flush
    no rad cap, thats why i though id drop the top hose off and fill it like that with a funnel?
  7. #7
    Forum User
    Join Date
    Mar 2004
    Location
    West Midlands
    Posts
    9,205
    Car
    MK1 Clio RTT
    Re: Coolant Flush
  8. #8
    Join Date
    Mar 2011
    Location
    Banbury
    Posts
    388
    Car
    Renault Clio 182
    Re: Coolant Flush
    No then fill it from the expansion tank put collant in the expansion tank until it stops filtering through run it up to temp and leave the lid of the level will start dropping once the thermostat opens so you will need to further fill it leaving the lid of will also let any air out the system whilst filling
  9. #9
    Forum User
    Join Date
    Mar 2004
    Location
    West Midlands
    Posts
    9,205
    Car
    MK1 Clio RTT
    Re: Coolant Flush
    awesome cheers
  10. #10
    ClioSport Trader
    Join Date
    Aug 2011
    Location
    Bedford
    Posts
    5,721
    Car
    DON'T SEND ME PM'S!!
    Re: Coolant Flush
    there's a bleed nipple in the upper hose, right near the water pump. Remove this, fill the system up until coolant comes out the bleed, the replace the screw. done.
  11. #11
    Forum User
    Join Date
    Mar 2004
    Location
    West Midlands
    Posts
    9,205
    Car
    MK1 Clio RTT
    Re: Coolant Flush
    right, done all the flush and topped it up, sweet, but my radiator fan aint kicking in now? its going just past 3/4 on temp guage, the fluid is bubbling and the fan aint kicking in, ideas? coolant is coming out the nipples when i open them so theres no air in the system
    ideas?
  12. #12
    Forum User
    Join Date
    Mar 2004
    Location
    West Midlands
    Posts
    9,205
    Car
    MK1 Clio RTT
    Re: Coolant Flush
    its going past 3/4 now, nearly upto max temp, ive just truned it off to let it cool down a bit, f**k sake -.-
    the fan worked fine til ive done the coolant flush
  13. #13
    Join Date
    Nov 2011
    Location
    Somerset / London
    Posts
    14,204
    Car
    CLIO RS2/ Turbo/Mk1
    Re: Coolant Flush
    As danny says, it will be an airlock, just need to bleed it through. Run it up a couple of times and stop it and keep doing it if in doubt, and leave the cap off while doing so.
  14. #14
    Forum User
    Join Date
    Mar 2004
    Location
    West Midlands
    Posts
    9,205
    Car
    MK1 Clio RTT
    Re: Coolant Flush
    all good, safe to leave it til tomorrow yeah? as im getting pissed off at it now
    my new actuator rod end dont fit, think its slightly to small, wont thread onto the needle thing
  15. #15
    Forum User
    Join Date
    Mar 2004
    Location
    West Midlands
    Posts
    9,205
    Car
    MK1 Clio RTT
    Re: Coolant Flush
    oh and coolant tastes f**king horrible, im there blowing into the header tank and it went in my mouth, still taste it now
  16. #16
    Join Date
    Nov 2011
    Location
    Somerset / London
    Posts
    14,204
    Car
    CLIO RS2/ Turbo/Mk1
    Re: Coolant Flush
    lol @ the tastes
    Thats a bummer about the actuator rod end, Im surprised at that, all the ones Ive seen have been the same thread.
  17. #17
    Forum User
    Join Date
    Mar 2004
    Location
    West Midlands
    Posts
    9,205
    Car
    MK1 Clio RTT
    Re: Coolant Flush
    reading up and apparantly some are metric and some are imperial (thread)
  18. #18
    Join Date
    Mar 2011
    Location
    Banbury
    Posts
    388
    Car
    Renault Clio 182
    Re: Coolant Flush
    LOL type d coolant tasted like s**t had that happen a few times
  19. #19
    Join Date
    Nov 2011
    Location
    Somerset / London
    Posts
    14,204
    Car
    CLIO RS2/ Turbo/Mk1
    Re: Coolant Flush
    Quote Originally Posted by Final Maxim View Post
    Which one do you need?
  20. #20
    Forum User
    Join Date
    Mar 2004
    Location
    West Midlands
    Posts
    9,205
    Car
    MK1 Clio RTT
    Re: Coolant Flush
    no idea, this is the one i bought
    http://www.ebay.co.uk/itm/3208939667...84.m1497.l2649
    its longer than a normal one,
    comparrison
Similar Threads
  1. Coolant - complete system flush & change [guide?]
    By Roy Munson in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 14-04-2011, 20:09
  2. Coolant change and flush on a Mk1 1.4 RT
    By donsrno1 in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 29-10-2005, 22:40
  3. Coolant Flush
    By rockport in forum Clio Discussion
    Last Post: 22-10-2002, 13:15
  4. Coolant Flush
    Last Post: 22-10-2002, 12:15
  5. flush fit valve - adaptor for pumping tyres up, where
    By coolspot007007 in forum Clio Discussion
    Last Post: 04-09-2002, 20:17
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
cliosport collant
renault clio coolant change
how to flush clio coolant system
where are the bleed nipples for coolant on renault clio located
coolant for renault clio
clio sport coolant change
clio 182 airlock
how to flush renault clio radiator
how to drain and refill a clio 1.4 16v coolant
cliosport bleeding cooling system
cliosport air in coolant
cliosport bottom radiator hose
2004 renault clio coolant bleeding
remove hoses cliosport.net
where is clio 182 coolant bleed valve
RENAULT CLIO 07 COOLANT
clio mk1 cooling
2004 renault clio coolant bottle
clio mk1 bleeding coolant
renault clio 1.4 16v coolant air lock
how do you remove clio 182 bottom radiator hose
car radiator cap clio mk1
drain coolant in renault clio sport
header tank renault clio sport 1.4
bleed nipples coolant on a renault clio
images of renault clio 182 radiator drain point
expansion tank in car bubbling renault clio mk1
how to empty a radiator system on a clio
clio 182 coolant change air bubble
renault clio how to bleed water
how to bleed radiator on renault clio
renault clio 2004 drain coolant and add some neat
rusty coolant clio
182 coolant flush
radiator flush clio
how best to flush the coolant on a Mk1 clio 16v
how to bled coolant system clio
clio 182 drain coolant
draining radiator on renault clio
renault clio 07 coolent flush
hw to flush coolent from renult clio mk 3
coolant bleed clio grande
cliosport.net clio 172 coolant airlock
mk1 clio coolant drain
draining clio 182 cooleant
cliosport.net guide to changing coolant on clio 182
renault clio cooling system bleed
renault clio 2004 radiator empty
clio 172 coolant hoses
clio bubbles in the water expansion tank
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
