Poor/No Radio Reception But Receives GPS
As title states my radio has poor or very little reception it has the standard head unit. However it does receive GPS for the built in sat nav. Wondering if anyone has any help on this? Also does the laguna gps antenna fit and work with the clio?
Thanks in advance.
Re: Poor/No Radio Reception But Receives GPS
GPS and radio don't use the same signal AFAIK so it just sounds like a sound system fault
I had this problem in my 172 cup a few years ago (obv not satnav) after much faffing about I swapped out the base for a unit + lead, cured it 100%. Think there is some powered amp or something in the base iirc
The aerial base is slightly larger than the standard clio aerial base, so presume the gps is in the same base?
Similar Threads
By sbridgey in forum Interior, ICE, Security, Lighting & Electrical
Last Post: 30-04-2011, 17:18
By Simon N in forum Interior, ICE, Security, Lighting & Electrical
Last Post: 09-03-2010, 19:45
By ChrisD172 in forum Interior, ICE, Security, Lighting & Electrical
Last Post: 09-07-2009, 18:43
By NED FLANDERS in forum Faults, Problems & Solutions
Last Post: 03-09-2008, 22:03
By peterh2 in forum Clio Discussion
Last Post: 06-03-2005, 18:33
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Visitors found this page by searching for:
gps aerial clio laguna same
clio bad radio reception
poor radio reception in new renault clio
05 renault laguna poor radio reception
2004 renault laguna poor radio reception
renault clio gps antenna
poor radio reception in renault laguna 3
renault laguna gps antenna location
renault clio 2 ph2 radio reception
no radio reception kenwood in clio
Renault Clio 172 radio reception
laguna radio reception
clio gps ariel
2008 laguna poor radio reception
Powered by
vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules:
Sphinx-based search
