Colour Coding spoiler
so this is my spoiler at the moment..
Im looking to colour code it but i dont know the best way about doing it... do i sand then plastic primer like the same as the badges i did or wha?
please help me out
Re: Colour Coding spoiler
yeah basically same as painting any other plastics mate...
sand and clean,
plastic primer,
hi-build primer (grey usually),
sand,
paint chosen colour,
lacquer,
done
can you get me a link for a good hi-build primer mate?
how many coats of each thing would you recommend?
Originally Posted by
DanEdser
best to ask someone else on good hi-build primers fella, i've only used car-plan hi-build grey primer so far but i think it does the job extremely well...
any way:
1 coat of plastic primer,
1-2 coats of hi-build (sanding in between, this depends on how smooth the texture is tbh mate, if its really smooth after one coat and a fine sanding with wet and dry stick to one, if not give it a second coat and sand again,
2-3 coats of colour based on how even and well you cover it, best to do it in thin layers so you dont get runs (dont worry if you can still see primer after the first coat of colour, the second coat should cover it all. with the third coat being for any parts you might have missed or to blend all the colour together so there is no discrepancy on the spray direction ie up-down and left-right)
and finally at least 3-4 coats of lacquer as it is an external part and will be more prone to fading, and chips etc
just make sure you leave a while for drying time between coats and either leave for 24 hours or a few hours in a heated room to harden the paint completely before fitting the spoiler,
p.s if you think something has gone wrong at any point in the process like runs or paint reacting (not enough drying time or contaminant), it is easier and cheaper to sort straight away than if you carry on to completion... sort this by allowing it to dry then flatting back and repeating the priming steps (all the way back if severe, hi-build if something like a run)
hope this helps mate
just get it done professionally, will only cost £40-50, you could easily spend £30-40 just on sand paper and the primers/paint/lacquer and it could still turn out looking crap
There is a full guide in the guides section on exactly this.
On one of the very last pages though.
tptds
true but he could have enough materials left over to colour code other bits like the bumper trim for example... (depending how much he buys)
either way get it done :L
Similar Threads
By 01chris02 in forum Clio Media
Last Post: 11-05-2012, 21:42
By cgap in forum Exterior & Bodywork
Last Post: 11-12-2007, 00:01
By Clare in forum Clio Discussion
Last Post: 23-08-2002, 15:48
By ClioJohn in forum Clio Discussion
Last Post: 24-07-2002, 17:38
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Visitors found this page by searching for:
sandpaper clio colour code
Powered by
vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules:
Sphinx-based search
