Page 3 of 3 FirstFirst 1 2 3
Results 41 to 46 of 46
  1. #41
    Join Date
    Nov 2008
    Location
    Hungary
    Posts
    192
    Car
    Clio Williams
    Re: Parts diagram needed for Gear linkage
    Quote Originally Posted by EVOgone View Post
    I have just got a new linkage bar and the old one has a resin ball and the new one has a softer plastic covering. Got a new no12 bush as well and the slop has gone but the gear shift is a bit stiffer (think its down to the softer plastic vs the harder resin. The new plastic covered one also has plastic covering the linkage conector at the end which makes it so it doesnt fit so i have cut this off so its the raw matal like the origional. Dont know if this is for a later linkage to gearstick rod but dont see why you would have it.
    In older cars the elbow joint consists of a clevis bar, metal bush, rubber spacer, bolt, small linkage (with uncovered head), washer and nut (washer and nut are not applied if there is a threaded plate on the clevis bar). The head of small linkage in newer cars is plastic covered, in this case the linkage consists of 'pivoted' gear linkage end, small linkage (plastic covered), washer and nut (like in Bigash's vid). This pastic covered one has got a taller head, this replaces the previous version's rubber spacer. This soft spacer tends to split.
  2. #42
    Join Date
    Jul 2006
    Location
    Burpspeed HQ Banbury,where else.
    Posts
    15,829
    Car
    182cup & 172 racecar
    Right guys, just warning about the #12
    As I said I fitted it the other week and thought all was well.
    Took the race car up the road and back (private of course) 1,2,3,3,3,3,3,3,3,fcuk, whats happened.
    Managed to get back to workshop, took sump guard off, #12 was hanging in by a nats whisker.
    Lady luck was on my side, circlip was on sump guard still.
    So a warning, these are a very tight fit, in the end I had to get the clip in place and knock it in with a socket and hammer.
    Thank God I took it for a run, and it didn't happen in Qualifying.
    I was fooled, I thought the clip had gone in, so don't make my mistake, make sure it is fully home before you drive it.
    Luv Tony.X
  3. #43
    Join Date
    Jul 2007
    Location
    Milton Keynes
    Posts
    4,832
    Car
    FF-Racing 182
    Aye fully agree Tony couldn't get mine fully in and it's on my list of to-do jobs
  4. #44
    Join Date
    Jul 2006
    Location
    Posts
    15,829
    Car
    Quote Originally Posted by BIGASH View Post
    Yes, well don't forget to do it, or you will be fooked. I was lucky.
  5. #45
    Join Date
    Dec 2012
    Posts
    61
    Car
    Focus rs
    Been using the search function and I need number 10 and 12 where can I get these from?
  6. #46
    Join Date
    May 2009
    Location
    Basingstoke
    Posts
    492
    Car
    Iceberg 172
    Renault.
Similar Threads
  1. which engine parts/gaskets needed for rebuild?
    By Robclio98 in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 17-04-2011, 21:47
  2. Parts needed for manual windows to electric
    By Stu_c in forum Interior, ICE, Security, Lighting & Electrical
    Last Post: 26-01-2006, 21:36
  3. Parts needed for the 172 24k service....
    By Alan in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 14-11-2005, 00:49
  4. Gear Linkage Lubrication Needed ?
    By JR in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 14-10-2005, 14:31
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
renault gearbox selector bush
renault clio gearbox linkage
clio sport 172 Gear Linkage Rods
renault clio engine diagram manual
renault clio gear linkage design
ep3 gear oil
renault clio 182 gear knob
Diagram for the gear Linkage for a seat 2006
clio gear linkage bush replacement
ep3 gearbox diagram
clio parts diagram
clio 182 gear link bushes
clio 172 gear diagram
renault clio gear assembly
clio172 how to fill gearbox oil
renault gearbox linkage 02 on
7700872205 renault
renault clio gearbox linkage picture
clio 172 gear selector
clio gearbox bush diagram
gear rod diagram
renault clio 172 Gear Linkage Rods
GEARCHANGE BUSH clio sport 172Gear Linkage
renault clio gearbox selector bush
renault clio gear selector linkage ball
ref 7700872205
gear box diagram clio sport
renault clio manual gearbox diagram
squeaky gear stick clio www.cliosport.net
205 long gear linkage rod
renault clio selector bush
gearbox oil change clio 182
clio sport 172 7700872205
race care gear change linkage partsclio 1149 ho to change gear box oilrenault clio 2005 power diagramrenault clio gearbox assemblyrenault clio mk1 gear linkagecar gear linkage gearbox linkage cliorenault svirtisrenault clio parts manualclio 182 gear diagramcar gearbox bushes diagramcliosport.net clio 172 gear linkage problemsclio gearbox linkage tooldigraam of a geargear diagramrenault clio gear box linkage partsrenault clio gear linkage drawing
