Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 44
  1. #21
    Join Date
    Nov 2011
    Location
    Somerset / London
    Posts
    14,114
    Car
    CLIO RS2/ Turbo/Mk1
    Re: Parts diagram needed for Gear linkage
    Assuming all you have altered is a slightly longer section of the rod between the lever and the bend in the rod, and given that there is essentially zero twist in the rod itself on this part, I find it hard to see how that is exaggerating the play so much really.
    Any pictures of the mods to the rod itself that might help shed light on why that is altering how it behaves.
  2. #22
    Join Date
    Jul 2007
    Location
    Ilkley, Leeds
    Posts
    3,780
    Car
    FF-Racing 182
    I just thought by it being longer then it would cause more of a pivot point on the change ( I am clueless though lol ) I will get photo's tonight and post up, also had video's but then my phone decided not to save them!
  3. #23
    Join Date
    May 2004
    Location
    Cheshire
    Posts
    2,930
    Car
    Pink Cup Racer
    Quote Originally Posted by Yanoo View Post
    Item 12 can cause huge play in the whole linkage if it's worn. If in doubt it's suggested to change it (its ref. number: 77 00 872 205 and approx £4 from Renault). As Danny said, Item 10 sometimes also can cause play if its bigger ball is worn or snapped. Only older Renaults use rigid plastic ball (it tends to snap or wear off), the newer ones use a flexible resin ball. Common problem that the bush of this small rod gets worn and results huge lateral play at the gear knob. I have a small metal bush for replacing this one, but my bush cannot be fitted if the long linkage has got a 'built in' pivot.
    I have just got a new linkage bar and the old one has a resin ball and the new one has a softer plastic covering. Got a new no12 bush as well and the slop has gone but the gear shift is a bit stiffer (think its down to the softer plastic vs the harder resin. The new plastic covered one also has plastic covering the linkage conector at the end which makes it so it doesnt fit so i have cut this off so its the raw matal like the origional. Dont know if this is for a later linkage to gearstick rod but dont see why you would have it.
  4. #24
    Forum User
    Join Date
    Feb 2006
    Location
    Ormskirk, West Lancs
    Posts
    3,319
    Car
    Civic Type R EP3
    Is this where the 'number 12' goes - in the centre of the pic? Mine's squeaky as hell here! Ordered the bush just in case it is that.
    IMAG0337 by foodbeast04, on Flickr
  5. #25
    Join Date
    Jul 2007
    Location
    Ilkley, Leeds
    Posts
    3,780
    Car
    FF-Racing 182
    Yes mate 12 goes into there
  6. #26
    Join Date
    Jul 2007
    Location
    Ilkley, Leeds
    Posts
    3,780
    Car
    FF-Racing 182
    I have taken both these video's with the car in gear, the play really is bad. Half of it seems to be cause by the selector shaft going up and down, Is there any way to stop this? I guess not as it needs to move to select the different gears. There seems to be play in the bush 12 but I don't know if it's a normal amount, Play also in the hole for the selector and the pin but don't know if the pin is worn or the hole in the selector. Looking at the video's what parts should I change? I'm thinking bush 12, and the pin 10. Can I change the spring 23 to try and stop the amount the selector goes up and down?
    What are 28, 29 and 30?
    Should I also change the actual selector shaft end?
  7. #27
    Join Date
    Jul 2006
    Location
    Burpspeed HQ Banbury,where else.
    Posts
    12,265
    Car
    182cup & 172 racecar
    I've just picked up No12,
    Bush Select R19 7700872205 £2.20 inc vat.
  8. #28
    Join Date
    Jul 2007
    Location
    Ilkley, Leeds
    Posts
    3,780
    Car
    FF-Racing 182
    Is it easy to fit Tony?
  9. #29
    Join Date
    Jul 2006
    Location
    Posts
    12,265
    Car
    Circlip pliers, 5mins.
  10. #30
    Join Date
    Jul 2007
    Location
    Ilkley, Leeds
    Posts
    3,780
    Car
    FF-Racing 182
    Perfect Ordered a set of them from Ebay this morning but was expecting it to be more difficult than that!
  11. #31
    Join Date
    Jul 2007
    Location
    Ilkley, Leeds
    Posts
    3,780
    Car
    FF-Racing 182
    Just ordered 10,12,13 and 30! Fingers crossed this fixes it! If not then think I need to look at the gear linkage end
  12. #32
    Forum User
    Join Date
    Feb 2006
    Location
    Posts
    3,319
    Car
    Civic Type R EP3
    You beat me to it! Was gonna ask how hard it is to fit cos I can't see how to do it, but then again I won't be fitting it cos I'm a desk dude.
  13. #33
    Join Date
    Jul 2007
    Location
    Ilkley, Leeds
    Posts
    3,780
    Car
    FF-Racing 182
    I'm useless with things like this! If I manage it I will take some photo's and explain it for you The tool only cost 2.10 delivered from ebay!
  14. #34
    Forum User
    Join Date
    Feb 2006
    Location
    Posts
    3,319
    Car
    Civic Type R EP3
    Cheers buddy! My mate will box it off for me, I just like to watch and understand stuff! Yeah I ordered the part off T21ADS here. Let me know how you get on. Does yours squeak it's tits off too? I can see in your video that it's split on the 'number 12' bush, is that why it's goosed?
  15. #35
    Join Date
    Jul 2007
    Location
    Ilkley, Leeds
    Posts
    3,780
    Car
    FF-Racing 182
    Haha sounds like the easier option
    Same he has sorted me out with lot's of bits recently!
    Will do, no not really just loads of play unfortunately. I wouldn't hear it squeak even if it did lol! I can't even hear when a wheel bearing goes in my car
  16. #36
    Join Date
    Jul 2006
    Location
    Posts
    12,265
    Car
    Take out circlip,
    pull downwards,
    12 will pull apart,
    put 12 back on yoke,
    push back into gearbox,
    refit circlip.
    Oh and put a little white grease on ball end before putting 12 on the end.
  17. #37
    Forum User
    Join Date
    Feb 2006
    Location
    Posts
    3,319
    Car
    Civic Type R EP3
    Quote Originally Posted by Tony Hunter View Post
    Take out circlip,
    pull downwards,
    12 will pull apart,
    refit circlip.
    Cheers Tony Toni Tone!
  18. #38
    ClioSport Trader
    Join Date
    Aug 2011
    Location
    Bedford
    Posts
    5,672
    Car
    DON'T SEND ME PM'S!!
    Attempt to Take out circlip,
    swear when the 4 different sizes of circlip pliers you have won't fit
    fight with it for 10 minutes until all blood has left your arms and it finally gives in
    pull downwards,
    12 will pull apart, and probably fall to pieces so you can't see how it should go back together
    remove and try again the other way up
    and again
    and again
    attempt to refit circlip
    push like f**k to make 12 go in far enough
    attempt to fit circlip
    hit 12 with something
    refit circlip
    Relise you should have greased inside 12 before fitting, so remove circlip.....
    EFA
  19. #39
    Join Date
    Jul 2007
    Location
    Ilkley, Leeds
    Posts
    3,780
    Car
    FF-Racing 182
    Sorry what?! lol I mis-read that at first
    Quote Originally Posted by Dan@519Automotive View Post
    EFA
    Haha that sounds more like I imagined it from looking at it the other night lol! I will await my cir-clip pliers not fitting and go from there
  20. #40
    Join Date
    Jul 2006
    Location
    Posts
    12,265
    Car
    EFA
    LOL
Similar Threads
  1. which engine parts/gaskets needed for rebuild?
    By Robclio98 in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 17-04-2011, 21:47
  2. Parts needed for manual windows to electric
    By Stu_c in forum Interior, ICE, Security, Lighting & Electrical
    Last Post: 26-01-2006, 20:36
  3. Parts needed for the 172 24k service....
    By Alan in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 13-11-2005, 23:49
  4. Gear Linkage Lubrication Needed ?
    By JR in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 14-10-2005, 14:31
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
renault clio gear linkage
clio gear linkage
renault gearbox selector bush
renault clio gearbox diagram
clio sport 172 Gear Linkage Rods
renault clio gearbox linkage
clio gear selector bush
clio gear linkage bush
renault clio automatic gearbox diagram
ep3 gear oil
renault clio gear linkage design
renault clio engine diagram manual
7700872205
Diagram for the gear Linkage for a seat 2006
renault clio 182 gear knob
clio gear linkage bush replacement
clio parts diagram
ep3 gearbox diagram
clio172 how to fill gearbox oilGEARCHANGE BUSH clio sport 172Gear Linkagegear rod diagramrenault gearbox linkage 02 onrenault clio 172 Gear Linkage Rodsrenault clio gearbox linkage picturerenault clio gear linkage problemrenault clio gear assembly7700872205 renaultmk1 clio gear stick assembleclio 172 gear selectorrenault clio gearbox selector bushrenault gear selector bushclio gearbox bush diagramgear linkage renault clio77 00 872 205renault clio gearbox diagram oil changerenault clio selector bush gearbox oil change clio 182205 long gear linkage rodgear box diagram clio sportref 7700872205clio 172 gear diagramclio sport 172 7700872205renault clio gear selector linkage ballgear linkage cliocliosport.net clio 172 gear linkage problemsclio 172 gear linkagesqueaking gear stick renault clio renault 19 europa part diagramrenault clio mk1 gear linkageclio 1149 ho to change gear box oil
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
