Re: My car sits wonky after coilover fitted
also is there a difference in height at the front
for instance most of the weights at the front so surely if say the nsf is to low it would lift at the osr
just guessing
by the looks of your springs your one on the right isn't turned right down
Originally Posted by
harvsurrey
That looks good Dan , people forget suspension needs weight transfer to work ,and if its slammed so the cog is through the floor it all goes to pot ,
I agree with that but that car would look miles better slammed IMO as most cars do.
I may be a bit off the mark here but I think 90% of people on here buy coilovers for the lowz and not the handling.
leeds_182
Yup. For a road car, you dont want to just slam it on the floor, ie:
I had exactly the same problem with my vmaxx mate! Jack it up, undo the shock bolts, turn the springs so the end tails sit identical (i.e both pointing to rear) put shocks back on and recheck height!
I don't know how, but this sorted mine out!!
leeds_182
I've had lower cars for sure
I'm just getting older and sensible I guess
Heres mine
Doesnt have baloon tyres anymore mind, So looks a tad strange, Drives well though, Nice playfull rear end when you want too.
Infact Jim might recognise the pic
Here's mine on Coilie's
Opinions welcome
^^ Need to clean the oil stain up
hows this got into whos got the lowest car all of a sudden lol
Can the petrol tank cause the difference?
It's a very small difference to notice. I never even looked at the adjusters when I had coilies, I just adjusted both sides until I had desired height. Who cares if they're slightly different as long as you can get equal height on both sides.
The Boosh!
It won't be AS GOOD not corner weighted but if he has the camber/caster etc set up it will be fine, surely? We're not all racing drivers who need to have their car corner weighted for nipping to Asda and back.
People need to take a step back here, the guy was asking for help not opinions on how good or s**t his coilovers are. I'm seeing it more and more recently and it's beginning to piss me off tbh i think it's uncalled for. Just to clarify this isn't aimed at Tony lol.
Who mentioned racing drivers?
Going down a country lane, over a bump, deer, rabbit ,fox runs out, brake!! 99% chance of finding the ditch, hedge etc.
You can't just go wacking things on willy nilly and expect them to work correctly.
As said before, Renault spend trillions.
At least give things a chance to work, by getting them set up correctly, you will enjoy them much more.
as i said earlier Tony , but people obviously don't get it .
It makes far more sense to understand how and why ,and then you realise you have to .........
banderson
Im gunna try this! I know for a fact theay arent identically placed.
Loving this thread hijack too
iLott
So, forgive me if i've misread.
But you know they are not seated correctly and are going to rectify it?
You got reverse rake on the go too?
the height will niggle at you for a while!! i almost went mad trying to set some coilovers up on mine once, id adjust it perfect, drive it up the road and back, and itll be completely different!! but most of it will be in your head after youve got it set up for the first time!!
and just to jump on the band wagon, mine now!!
and im not happy with it, need to lower the NSR corner slightly more!!
i think a lot of it may be down to a disproportional amount of the weight on the O/S/F corner where the engine is placed.
constant tweeting for the next few weeks may eventually leave you satisfied, or in a straight jacket!! enjoy!
Struggler
Explains why your username is struggler! Get back in your straight jacket :P
Similar Threads
By Clio_16v_boy in forum Engine, Gearbox, Exhausts & Running Gear
Last Post: 22-10-2006, 22:49
By clio172-squeeky in forum Clio Discussion
Last Post: 03-05-2006, 09:24
By modifiedmadness in forum Engine, Gearbox, Exhausts & Running Gear
Last Post: 10-01-2006, 02:15
By richy22 in forum Engine, Gearbox, Exhausts & Running Gear
Last Post: 09-11-2003, 16:41
By wongy008 in forum Clio Discussion
Last Post: 14-04-2003, 21:32
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Visitors found this page by searching for:
why does my car look wonky after fitting coilovers
suspension higher after coilovers fitted
fitting coilovers completely different height
Powered by
vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules:
Sphinx-based search
