DCI power delivery problem
Recently the car has been hesitating to accelerate a little when I accelerate.
For example the other day I put my foot to the floor in 2nd and there was NO power for around 2-3 seconds (around 2000rpm) before it starting pulling.
Last night driving home from work it was accelerating very uneven. Put my foot down there was a bit of power, then none and then a bit more then none etc.
Any ideas anyone?
Re: DCI power delivery problem
EGR Valve?
Give it a good clean: GUIDE HERE
I cleaned the EGR on the Mundaneo - took away all the hesitancy (and clouds of black smoke).
I have the exact same problem on the dci, i cleaned the egr valve and it was fine for a day or so then it happened again!
So i unplugged the egr valve and it drove fine. ordered a new one though as i don't like the idea of it not being plugged in.
Cheers thought it would be the egr. Getting it looked at today.
Anyone know anything about blanking plates? Someone told me they improve performance slightly ?
I don't know much about blanking them but imo its more hassle than its worth
Yep, egr valve was full of gunk so it's been cleaned and it's now running fine.
However one of the glow plugs came up on the diagnostics as well and it needs replaced but it's stuck in place and the guy doesn't want to force it out in case it snaps and gets left in there. Put some wd40 on it to sink in though and fingers crossed that will loosen it.
Glow plugs only aid during start up dude so not a major problem
Use some fuel additive cleaner, for good measure should keep you're injectors in better health and stop them getting gunked up (like mine did) i used one called Diesel DTOX i think was a big help
http://www.cartuningparts.co.uk/img/...518667_500.jpg
Originally Posted by
Owen_m
Lol got some today already. Gonna stick it in next time I fuel up.
I just pored it in outside the shop lol i got it on trade at halfords
should work well bud. keeps you're engine healthy as well
Says it increases performance, does it?
Only putting it in to clean the crap out and keep engine healthy
I should imagine it aids you're power, because of gunky injectors etc. but i've used most my tank of fuel and not noticed any difference.
In my limited experience in diesel engines of nearly two years as an apprentice, It won't make any difference. Good for the health of you're expensive fuel system though
its more of a diesel engine cleaning agent, the supposed ' extra power ' comes from the added cetane ( diesel version of similar octane for petty engines )
forgot to post and ask in here, did you find any oil'y deposits on the EGR valve contained within the gunk ?
oil found there can indicate early signs of turbo oil seals going.
DCI RAZ
Ok cheers
Not sure had it done at garage.
Such an easy job dude, not worth going to the garage if you ever need to do it again. 10 mm socket and extension plus an 8 mm socket are all you need
Similar Threads
By dan-hipgrave in forum Engine, Gearbox, Exhausts & Running Gear
Last Post: 02-09-2005, 00:14
By edde in forum Engine, Gearbox, Exhausts & Running Gear
Last Post: 01-01-2004, 16:32
By Paul16V in forum Clio Discussion
Last Post: 10-11-2002, 00:32
Last Post: 09-11-2002, 23:32
By Paul16V in forum Engine, Gearbox, Exhausts & Running Gear
Last Post: 27-10-2002, 00:46
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Visitors found this page by searching for:
clio dci no power at 2000 rpm
Powered by
vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules:
Sphinx-based search
