Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2007
    Location
    Newmarket, Suffolk
    Posts
    879
    Car
    Arctic FF 182
    Rear suspension problem - wobbly feel?
    I just bought a Clio 182 fairly cheaply! No major problems but something is wrong with the rear suspension - the ride height is uneven and the back of the car is very soft to push down? When driving it feels a bit wobbly from the back.
    What is the most likely cause of this on these cars - shocks, springs? I will have it on ramps in a few days but want to be prepared!
  2. #2
    Join Date
    Feb 2008
    Location
    Bushey Hertfordshire
    Posts
    4,567
    Car
    RS2'ed 172 Cup
    Probably shagged rear shocks.
    Not uncommon.
    The car won't sit 100% even at the rear normally anyway though due to (IIRC) due to the fuel tank.
  3. #3
    Join Date
    Apr 2007
    Location
    Newmarket, Suffolk
    Posts
    879
    Car
    Arctic FF 182
    Re: Rear suspension problem - wobbly feel?
    That's the answer I was hoping for - just had a look and can't see any cracks on the springs.
  4. #4
    Join Date
    Jul 2006
    Location
    Burpspeed HQ Banbury,where else.
    Posts
    12,274
    Car
    182cup & 172 racecar
    Could have had a broken spring at sometime, and the wrong one has been fitted, say off a 1.2 or similar.
  5. #5
    Join Date
    Aug 2010
    Location
    Wales
    Posts
    188
    Car
    clio 182
    I would check the rear dampers for oil leaks I have had 4 new rear dampers since Jan 2012, 5,000 miles til I noticed the oil leaks on the first set.
    Renault changed them for me under warranty, second set were leaking after 80 miles or 1 day later.
    See more info here http://www.cliosport.net/forum/showt...andard-dampers
  6. #6
    Join Date
    Apr 2007
    Location
    Newmarket, Suffolk
    Posts
    879
    Car
    Arctic FF 182
    I just bought a pair from Renault, I will keep an eye on them when they are fitted.
  7. #7
    Join Date
    Apr 2007
    Location
    Newmarket, Suffolk
    Posts
    879
    Car
    Arctic FF 182
    Just changed the rear shocks, seemed pretty knackered. Found a broken spring - are there any aftermarket springs that will fit or is it a trip to Renault again (I have the cup packs)? Eurocarparts have springs that 'will fit', but they are the same part no. as all the other Mk2 Clios.
    http://www.ebay.co.uk/itm/Anschler-R...ht_1110wt_1392
Similar Threads
  1. Rear suspension problem
    By Jonny2908 in forum Suspension, Brakes, Wheels, & Tyres
    Last Post: 25-04-2012, 09:54
  2. rear suspension problem
    By MattRS182 in forum Suspension, Brakes, Wheels, & Tyres
    Last Post: 18-01-2009, 16:39
  3. Rear suspension problem
    By jareh in forum Suspension, Brakes, Wheels, & Tyres
    Last Post: 21-04-2008, 14:59
  4. problem with rear suspension
    By Middo in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 12-05-2007, 13:08
  5. Rear Suspension Problem - 182 Cup
    By ClioF1 in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 19-04-2006, 01:01
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
clio suspension problems
clio 182 suspension problems
rear suspension problems
clio 182 unlevel rear suspension
clio rear suspension problems
clio 182 rear shock problems
rear suspension feels wobbly
clio rear suspension bouncing
wobbly car renault
clio rear end suspension soft
renault clio rear suspension problem
rear shocks site:cliosport.net
car feels wobbly when driving
renault clio suspension problems
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
