Like Dan said earlier, it's always a chance you take with a 2nd hand engine as you never really know what you are buying.
Sometimes cutting your losses is a good idea but these cars aren't worth much intact but not working so I'd urge you to see it thru and drop a working lump in (again) or break it.
Gutted for you though
Mick
Re: Belts again????!!!!!!!
Gutted Donna
No chance am i doing again!
Saw on ebay a few 182s non working engines that have sold.
Not sure if anythings salveageable re: the engine, as the CAT, Lambda etc was all NEW in November, and the belts, pulleys etc were all new 8 weeks ago..
Have asked Ant, but will get rid of the shell, interior and whatevers not f**ked.
Ideally want it to go in one as i dont want it lying in my road half of it missing, plus declared it SORN yesterday as tax was due..
Lovely.
x
Bad news Donna
*hugs*
I would personally put a new engine in, and punt it straight away. Someone will make a fair bit of cash doing it themselves.
Ta for everything Ant.. Post up in for sale guys
No problem
Belt went on my ph1, sold in 30 mins as non runner, did have some nice bit though, sorry to hear about ur bad luck, cars can suck some times
Originally Posted by
Scrooge
Belt and tensioners all ok.
that belt is too tight, you can see the tensioner is WAY past where it should be
god!!! dejavieiw! belt was to tight on mine when i bought it and that was done at renault dealer by the service history! buggered the dephaser and put the timing out! i got away with new rings and top end rebuild and picked it up today! i thought about second hand engine but no thanks! you dont know what your getting!
rebuild only! this is only my opinion as i never even thought about breaking or selling mine!
question for fred though? i had oil on my pistons and plugs how would this get there if the belt is to tight?timing out out mixture wrong?
sorry donna for loss!
only way oil can get in there is valve stems, rings, cracked block or head, you do get some oil back through the breather if its overfull or cornering HARD
I'm a tw@t and thought about the money was cheaper to get a 2nd hand engine than to rebuild..
Selling it as it is now, i have no more time money or effort i want to waste on it
cheers fred my engine exactly!sorted with a rebuild!whats caused this? donnas?
Fred@BTM
Fred@BTM
you can't possibly know that without seeing the marks. If the head's ever been skimmed, the tensioner will sit differently.
hence why you can't skim the heads (well you can a tiny bit, but renault say no for the reason you stated)
That was not too tight, timing was perfect aswell.
from my experience, the tensioner should never pass 12 o'clock, if it does we reject the kit and fit another (causes a random tap at idle)
Similar Threads
By Scudetto in forum Clio Discussion
Last Post: 22-07-2002, 16:16
By Griff in forum Clio Discussion
Last Post: 15-07-2002, 12:51
By JamesG in forum Clio Discussion
Last Post: 10-07-2002, 20:22
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Visitors found this page by searching for:
Nobody has landed on this page from an internet search engine.
Powered by
vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules:
Sphinx-based search
