Massive over fueling and problems with immobiliser - clio 182 trophy
A friend of mine who doesnt have access to the forum, has recently rebuilt his trophy engine after a valve failure.
Since then the car has been massively over fueling, leaving a black burnt fuel trail all the way up the back of the car, it also hunts around on idle and it isnt very smooth running at all. When cold it doesnt want to pull away either, but once warmed up it seems to be ok.
. It's now having problems firing up due to the immobiliser as well,. Could these two be linked or are they two seperate ?
He swears the timing is correct on it but if anyone else has had a similar experience please share
Re: Massive over fueling and problems with immobiliser - clio 182 trophy
I'd check the oxygen sensor and look for air leaks. Sure it's immobiliser and not the tdc sensor playing up?
BTW: Are you collecting 1*2s?
timing would be the first thing to have checked
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Visitors found this page by searching for:
clio overfueling
clio 182 overfueling
site:cliosport.net clio 182 oxygen sensor error
over fueling cliosport.net
over fuelling problems
car is massively over fueling on idle
Powered by
vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules:
Sphinx-based search
