Results 1 to 16 of 16
  1. #1
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    539
    Car
    mk2 ph2 1.2 16v
    FK euro rear lights
    Really want a set of FK automotive taillights, can anyone tell me if there's any difference between these two? Obviously its saying that one if for a mk2ph1 and the other for a mk2ph2 but i thought the rear light fittings were the same? Would the ph1 lights fit my ph2? Since there's the best part of £40 difference for from what i can see are the exact same lights?
    ph1
    http://r.twenga.co.uk/g3.php?pg=VDs1...hkNzZjMDc5Mg==
    ph2
  2. #2
    Re: FK euro rear lights
    On the ph1, the sidelight is at the top, whereas on the ph2 it's at the bottom. That's on the standard set of lights.
    I saw some 'Lexus' lights fitted on a lads ph2, that were meant for a ph1, and the top of his light was lit up like on a ph1. Maybe this is the case with these, not sure though.
  3. #3
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    539
    Car
    mk2 ph2 1.2 16v
    Ok thanks, would the holes for the bulbs not be the same size anyway though? Although they may be intended for different bulbs would it really make a difference since its a clear background for both anyway and i have silvervision indicator bulbs anyway?
  4. #4
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    539
    Car
    mk2 ph2 1.2 16v
    Major overuse of the word anyway just there, sorry.
    Also, has anyone seen these fitted or better yet got a picture? Since they're so cheap I'm very tempted
    http://www.carparts-tuning.co.uk/en/...aign=become_uk
  5. #5
    As far as I know everything would be the same, it's just that (I think) the top would light up rather than the bottom bit (with the LEDS) for the sidelights. That's the only difference I can think of!
  6. #6
    Join Date
    Dec 2011
    Location
    Plymouth
    Posts
    3,407
    Car
    8 Lives Remaining.
    AFAIK you can use Ph.2 holders in Ph.1 lights and vice versa without a problem. I don't see why you couldn't wire in aftermarket blocks with either configuration if you wanted to.
    With the last link though, if you wire it up as a Ph.1, you would have the LEDs as foglights. I don't know if that would be OK.
  7. #7
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    539
    Car
    mk2 ph2 1.2 16v
    Thats great news since i just found a set even cheaper, thank you very much for your help
  8. #8
    Join Date
    Dec 2011
    Location
    Plymouth
    Posts
    3,407
    Car
    8 Lives Remaining.
    Just found this saved on my computer. You might find it handy.
  9. #9
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    539
    Car
    mk2 ph2 1.2 16v
    Not really sure what you mean McGherkin when you say about wiring aftermarket blocks (sorry that i'm a noob) is there any way i could wire it up differently so that it would work as it should for my car? (bearing in mind i have little to no knowledge of electronics) thanks
  10. #10
    Join Date
    Dec 2011
    Location
    Plymouth
    Posts
    3,407
    Car
    8 Lives Remaining.
    Well, the blocks will either be configured for a Ph.1 (with the brake light at the top), or Ph.2 (with the brake light at the bottom). You have a Ph.2, but there's nothing stopping you buying blocks for a Ph.1 and swapping the wires over in the connector (see my last post) so that the right lights illuminate.
  11. #11
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    539
    Car
    mk2 ph2 1.2 16v
    Ok that is diagram is very helpful, can the part that plugs into the socket be moved about a bit so it would work as it should or is it like a fixed unit?
  12. #12
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    539
    Car
    mk2 ph2 1.2 16v
    sorry I'm constantly 1 post behind you here haha
  13. #13
    Join Date
    Dec 2011
    Location
    Plymouth
    Posts
    3,407
    Car
    8 Lives Remaining.
    Well, the wires have to be swapped around when going from Ph.1 to Ph.2 OEM lights, so I'd say you can swap them about. I don't have the car at the moment so I can't go out and check how easy it is
  14. #14
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    539
    Car
    mk2 ph2 1.2 16v
    Ok thanks, would i definitely have to buy ph1 blocks or could i just fiddle around with the existing one? Ok thats fine, but do you know off the top of your head if i'd need any equipment to swap them about? Being 18 i don't own a soldering iron or any tools other than like a hammer and a screwdriver lol
  15. #15
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    539
    Car
    mk2 ph2 1.2 16v
    Found a guide on how to do it, thanks for your help
    http://www.cliosport.net/content/gui...ster_guide.pdf
  16. #16
    Join Date
    Dec 2011
    Location
    Plymouth
    Posts
    3,407
    Car
    8 Lives Remaining.
    Quote Originally Posted by Barnett View Post
    Get one! They're not expensive. I have plenty of tools because I'm an engineer, but a socket set, soldering iron and a set of screwdrivers are essential
    And forgot about that guide lol
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
swapping clio rear lights
clio fk rear lights
clio euro lights
clio sport fk headlights
fk euro clio
euro clio lights
clio 172 rear light layout
clio mk2 fk rear headlights
euro clio rear lights
clio fk lights
clio fk euro lights
euro rear light
clio fk euro
c;io sport fk headlights
clio fk rear lights lit
clio euro rear lights
clio european lights
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
