Results 1 to 12 of 12
Thread: RE: Oil change
  1. #1
    Forum User
    Join Date
    Mar 2012
    Posts
    51
    Car
    Silver 172 cup
    RE: Oil change
    Hi,
    Planning to do an oil and filter change next Sunday. Not done one of these before so need a few tips, i.e.:
    • Specific oil to use (by brand) - topped up with 5w40 in the past but wondering if there was a specific brand to use
    • Where to buy the filter from
    • Other parts required/ recommended during change
    • Time taken to do the job and if possible a guide to doing so?
    • Quantity of oil to buy?
    • If any members buy all their required parts/oil from one trusted/good value place then I would like to know where!
    • I own a 172 cup - I presume parts and oil requirements are the same as 182? Just me and my mate are planning to split the cost of the oil and do this at the same time.
    Cheers,
    Luke
  2. #2
    Join Date
    Jul 2004
    Location
    Wiltshire.
    Posts
    12,290
    Car
    itb'd 428'd & caged
    Re: Oil change
    Specific oil to use (by brand) - Any decent fully synth 5 - 40, id choose titan Pro S or whatever it's called nowadays
    Where to buy the filter from - Renault - IMO always buy genuine
    Other parts required/ recommended during change the correct tool to undo the sump plug
    Time taken to do the job and if possible a guide to doing so? See below
    Quantity of oil to buy? 5 ltr's should do it
    If any members buy all their required parts/oil from one trusted/good value place then I would like to know where! Wests renault for the filer, Opie Oils for the Oil
    I own a 172 cup - I presume parts and oil requirements are the same as 182? Just me and my mate are planning to split the cost of the oil and do this at the same time. Yes, parts are the same
    To change, it's the same as any other car, with the main points being the right tool to undo the sump plug, and if you find you don't have one, then the metal square rod that runs through a house door to join the door handles will work.
    You may have a problem getting to the oil filer, as space at the front is tight - if so, undo the 2 10mmbolts holding the fuel rail guard on, this give you some more space
  3. #3
    Forum User
    Join Date
    Mar 2012
    Posts
    51
    Car
    Silver 172 cup
    Re: Oil change
    Do you think its worth taking to a local garage to do this job? How much will I save by doing it myself (£) if approx prices locally are known?
    Just thinking - stamp in the book, receipt from garage, won't have to buy the oil or have the hassle of doing the job myself?
  4. #4
    Join Date
    Mar 2012
    Location
    Peterborough
    Posts
    673
    Car
    Renault Clio 1.2 mk3
    Re: Oil change
    Quote Originally Posted by pench View Post
    All depends on how confident you are and your abilities. But for all the bits would probably cost less than half of an independent garage would charge for the same job
  5. #5
    Join Date
    Mar 2005
    Location
    Northfield, Birmingham www.clioguide.tk
    Posts
    15,646
    Car
    Z3, ph1 172, S7
    Re: Oil change
    Where are you based?
  6. #6
    Join Date
    Dec 2006
    Location
    High Wycombe- Bucks
    Posts
    963
    Car
    Arctic Blue FF 182
    Re: Oil change
    Quote Originally Posted by theduck View Post
    As above, as you might find a local member on here who would do it for you for a couple of beer tokens.
  7. #7
    Join Date
    Oct 2010
    Location
    Baildon, West Yorkshire
    Posts
    152
    Car
    Renault Clio 178
    Re: Oil change
    The last time I changed mine I think the bits cost about £40 for the oil, filter and new sump washer. That was using Carlube Triple R Fully synth and genuine filter and sump washer.
    I always get mine serviced at a garage every year to get the stamp but change the oil every 5 - 6k myself.
  8. #8
    Forum User
    Join Date
    Mar 2012
    Posts
    51
    Car
    Silver 172 cup
    Re: Oil change
    Based in altrincham south manchester. Will enquire at my local garage today and see how this compares to doing it myself.
    Luke
  9. #9
    Join Date
    May 2008
    Location
    Preston
    Posts
    712
    Car
    Clio 182 arctic
    Re: Oil change
    Luke
    I would have a go yourself bud.
    Its one of those thing that once you have done it once, you will wonder why you never did it in the past. A saving of about £40 for half hours work is a great feeling. Plus it is one of those jobs that you can't really get wrong provided you have the right oil grade etc.
    If its your first time, couple of tips that will help make it easier.
    The sump plug socket is an 8mm square, well worth buying
    Put some rags underneath the oil filter before you remove it. It leaks a bit of oil when removed.
    Put the sump plug back in before you start pouring the new oil in. Or there will be much swearing to follow.
    Have some old cardboard underneath whatever you're using to catch the oil.
  10. #10
    Join Date
    Mar 2011
    Location
    Netherlands
    Posts
    1,065
    Car
    FF Arctic blue 182
    Re: Oil change
    Renault reccomends replacing the ring that goes under the sump plug aswell
  11. #11
    Forum User
    Join Date
    Mar 2012
    Posts
    51
    Car
    Silver 172 cup
    Re: Oil change
    That's great cheers. Think I'll have a go this afternoon. There's a halfords just down the road from me- can I get everything I need from there?
  12. #12
    Join Date
    May 2008
    Location
    Preston
    Posts
    712
    Car
    Clio 182 arctic
    Re: Oil change
    You can do yes, they even do the little sump plug washer http://www.halfords.com/webapp/wcs/s...egoryId_256261
    A funnel is a great buy. The bigger the better really to prevent it overflowing but it depends how high you are raising the car off the ground.
    http://www.halfords.com/webapp/wcs/s...egoryId_255216
    Sump drain plug key 8mm
    And either a jerry can or a large container from home to store the old oil in, you can then go to the local tip and pour it in a drum and reuse the container. Aslong as the container holds 5l you should be ok
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
clio mk3 oil change
clio mk3 oil filter
what tools for oil change on clio sportwhere is the oil sump on a clio mk 3hoq ro chNGW OIL IN RENAUKT CLIOchanging oil clio mk3clio mk3 1.4 sump oil capacitymyself and local garage stampoil change clio mk3clio mk3 sump plugclio mk3 1.2 oil filter locationhow ro do oil change on clio sportclio mk3 sump plug 1.4mk3 clio engine oil change sump nut
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
