heaters no working ??
hey people just a quick question really , only just noticed as was bit chilly today that my heaters aint working? when i turn it up to blow more air out ect it does nothing ? no cold air no warm air nothing like its turnt off :/ just wondered if it could be a fuse or something ?
thanks Adam
Re: heaters no working ??
no gas or reisistor gone mate
it will be your heater resister. under the driverside window wiper, lift your bonnet lift up your wiper (dont scratch the bonnet) take the plastic trim off and you will see a connector with about 7ish wires on top. what its connected into is your resister (couple lil screws or torques screws to remove it) i think there roughly bout £100 new so find a friend with a multimeter to test it before lol
easy way to tell just bridge pin's 1&5 and the fans will come on then you know its the resistor
and there £30 to fix look on ebay for the repair services..
thanks for the replys
will look in morning when its light
by that do i get a bit of wire and touch either wire 1+5 ? if they come on then its the resistor that needs replacing ?
thanks Adam
^^^ Yes just use a bit of wire and again if the fan works its the rheostat(resistor )that has gone circa £120 new from the stealers
E bay is good for the repair service like the other guys said bridge 1-5 if spark its deffo the reisistor I need a new one but can cope at moment not good when it's raining down in sunny Wales
Sweet I'l be checking it once I get home from work , I was in Wales weekend gone and was actually sunny for a change ,every other time I go it's pouring down lol cheers mate il look on eBay if its it
Lol that was the weekend I worked but it's been terrible since mate let us know how you get on with te problem mate
Is it the plastic strip with the one clip on the left hand side ? Undo that then take it out ? Thanks Adam
yeah its under the drivers side scuttle panel see below pic of where it is
and what it looks like with the panel removed the offending article is on the far right of the hole in the pic
Originally Posted by
ADY 554D
Thanks for the pic I now know what im looking for
when I bridge the wires do I have I disconnect the resister ? Also may be a dumb question but what one is 1-5 is it the 1st wire and the last wire ? Thanks
Yeah disconnect it and from memory there numbered but pretty sure it is the first and last ones
ADY 554D
Thanks matey il shall be doing it in morning thanks again
think ive got the same problem but not sure what you mean by bridge the connections.
is there a step by step guide as am really bad with electrical stuff
bazpro
disconnect the multi plug that goes into the rheostat (resistor) you will see the pins are numbered 12345 get a peice of wire or cable anything that will complete a circuit and join pins 1&5 together the fans should then start blowing full power obviously you will need the ignition on and the heaters turned on in the car..
quick pic to try and explain
thanks mate will try it tommorrow
Just about to try this now, some one said make sure you lift wiper up and don't scratch bonnet ? Have I go to lift wiper up ? Or can I do it with it just as it is ?
right ive done what you lot said and i bridged the number 1-5 it went like 5-4-3-2-1 and when i did that my fans kicked in ? so take its the resister then? whats worth doing buying a new one or get the repair service thing from ebay ? whats that do? easy to fix ? also just wondered if any one has a link to it? thanks adam
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Visitors found this page by searching for:
site:cliosport.net can i bridge pins 1 and 5 on clio heater
Powered by
vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules:
Sphinx-based search
