Page 1 of 2 1 2 LastLast
Results 1 to 20 of 25
  1. #1
    Forum User
    Join Date
    Sep 2011
    Location
    Harlow Essex
    Posts
    376
    Car
    RB 182
    heaters no working ??
    hey people just a quick question really , only just noticed as was bit chilly today that my heaters aint working? when i turn it up to blow more air out ect it does nothing ? no cold air no warm air nothing like its turnt off :/ just wondered if it could be a fuse or something ?
    thanks Adam
  2. #2
    Join Date
    Mar 2012
    Location
    s wales
    Posts
    349
    Car
    172 sport
    Re: heaters no working ??
    no gas or reisistor gone mate
  3. #3
    Join Date
    Aug 2011
    Location
    harlow essex
    Posts
    50
    Car
    clio 172 2002
    it will be your heater resister. under the driverside window wiper, lift your bonnet lift up your wiper (dont scratch the bonnet) take the plastic trim off and you will see a connector with about 7ish wires on top. what its connected into is your resister (couple lil screws or torques screws to remove it) i think there roughly bout £100 new so find a friend with a multimeter to test it before lol
  4. #4
    Join Date
    Jul 2006
    Location
    Mansfield,nott's
    Posts
    707
    Car
    Yozza'd Artic 182~FF
    easy way to tell just bridge pin's 1&5 and the fans will come on then you know its the resistor
    and there £30 to fix look on ebay for the repair services..
  5. #5
    Forum User
    Join Date
    Sep 2011
    Location
    Harlow Essex
    Posts
    376
    Car
    RB 182
    thanks for the replys will look in morning when its light
  6. #6
    Forum User
    Join Date
    Sep 2011
    Location
    Harlow Essex
    Posts
    376
    Car
    RB 182
    by that do i get a bit of wire and touch either wire 1+5 ? if they come on then its the resistor that needs replacing ?
    thanks Adam
  7. #7
    Join Date
    Aug 2010
    Location
    Midlands
    Posts
    5,149
    Car
    TCR'd 182
    ^^^ Yes just use a bit of wire and again if the fan works its the rheostat(resistor )that has gone circa £120 new from the stealers
  8. #8
    Join Date
    Mar 2012
    Location
    s wales
    Posts
    349
    Car
    172 sport
    E bay is good for the repair service like the other guys said bridge 1-5 if spark its deffo the reisistor I need a new one but can cope at moment not good when it's raining down in sunny Wales
  9. #9
    Forum User
    Join Date
    Sep 2011
    Location
    Harlow Essex
    Posts
    376
    Car
    RB 182
    Sweet I'l be checking it once I get home from work , I was in Wales weekend gone and was actually sunny for a change ,every other time I go it's pouring down lol cheers mate il look on eBay if its it
  10. #10
    Join Date
    Mar 2012
    Location
    s wales
    Posts
    349
    Car
    172 sport
    Lol that was the weekend I worked but it's been terrible since mate let us know how you get on with te problem mate
  11. #11
    Forum User
    Join Date
    Sep 2011
    Location
    Harlow Essex
    Posts
    376
    Car
    RB 182
    Is it the plastic strip with the one clip on the left hand side ? Undo that then take it out ? Thanks Adam
  12. #12
    Join Date
    Jul 2006
    Location
    Mansfield,nott's
    Posts
    707
    Car
    yeah its under the drivers side scuttle panel see below pic of where it is
    and what it looks like with the panel removed the offending article is on the far right of the hole in the pic
  13. #13
    Forum User
    Join Date
    Sep 2011
    Location
    Harlow Essex
    Posts
    376
    Car
    RB 182
    Quote Originally Posted by ADY 554D View Post
    Thanks for the pic I now know what im looking for when I bridge the wires do I have I disconnect the resister ? Also may be a dumb question but what one is 1-5 is it the 1st wire and the last wire ? Thanks
  14. #14
    Join Date
    Jul 2006
    Location
    Mansfield,nott's
    Posts
    707
    Car
    Yeah disconnect it and from memory there numbered but pretty sure it is the first and last ones
  15. #15
    Forum User
    Join Date
    Sep 2011
    Location
    Harlow Essex
    Posts
    376
    Car
    RB 182
    Thanks matey il shall be doing it in morning thanks again
  16. #16
    think ive got the same problem but not sure what you mean by bridge the connections.
    is there a step by step guide as am really bad with electrical stuff
  17. #17
    Join Date
    Jul 2006
    Location
    Mansfield,nott's
    Posts
    707
    Car
    Quote Originally Posted by bazpro View Post
    disconnect the multi plug that goes into the rheostat (resistor) you will see the pins are numbered 12345 get a peice of wire or cable anything that will complete a circuit and join pins 1&5 together the fans should then start blowing full power obviously you will need the ignition on and the heaters turned on in the car..
    quick pic to try and explain
  18. #18
    thanks mate will try it tommorrow
  19. #19
    Forum User
    Join Date
    Sep 2011
    Location
    Harlow Essex
    Posts
    376
    Car
    RB 182
    Just about to try this now, some one said make sure you lift wiper up and don't scratch bonnet ? Have I go to lift wiper up ? Or can I do it with it just as it is ?
  20. #20
    Forum User
    Join Date
    Sep 2011
    Location
    Harlow Essex
    Posts
    376
    Car
    RB 182
    right ive done what you lot said and i bridged the number 1-5 it went like 5-4-3-2-1 and when i did that my fans kicked in ? so take its the resister then? whats worth doing buying a new one or get the repair service thing from ebay ? whats that do? easy to fix ? also just wondered if any one has a link to it? thanks adam
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
site:cliosport.net can i bridge pins 1 and 5 on clio heater
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
