Page 1 of 2 1 2 LastLast
Results 1 to 20 of 26
  1. #1
    Am i missing Stub axle washer/spacer (pic)
    I have just removed the rear brake discs to change them for new bearings and discs and I was expecting to see a washer/spacer behind them and there was nothing behind either side..... Nothing was stuck in the back of the disc and nothing on the stub axle, have the previous discs been installed without the washers or have they magically dissapereard ?? :/
    Car is 51 phase 2 -172 (non cup)
  2. #2
    Area Rep
    East Anglia
    Join Date
    Sep 2004
    Location
    Suffolk
    Posts
    10,771
    Car
    Monaco 172
    Sure it's not on the back of the disc? When stuck on they look like part of the bearing.
    Will have a chamfered hole
  3. #3
    Re: Am i missing Stub axle washer/spacer (pic)
    Unfortunately no chamfered hole
    I take it there is a washer behind all clio's that have rear discs and not just cup models as that is where I saw that there should be a washer behind in other threads
  4. #4
    Forum User
    Join Date
    Feb 2008
    Location
    N Yorkshire
    Posts
    2,008
    Car
    Dodgy one
    Its missing
  5. #5
    Quote Originally Posted by rich-6 View Post
    Its missing
    Train to work until Renault can get two in on Wednesday then
  6. #6
    Join Date
    Aug 2010
    Location
    Corwen, North Wales
    Posts
    923
    Car
    172 Cup RS2'd-306HDi
    Isn't it still on the hub? I'm sure that's the silver bit right on the end. This is mine after it shattered on a track day -
    The spacer is right on the back... See it?
    Try prying it off with a flat end screw driver
  7. #7
    Join Date
    Aug 2010
    Location
    Corwen, North Wales
    Posts
    923
    Car
    Plus your bearing wouldn't last two weeks without that spacer
  8. #8
    It isn't a spacer at the back you see there, it's moulded to the stub, I've tried prying it off and then cleaned it to see it is moulded,
    I thought they wouldn't last two mins either without the spacer being there so I'm not sure.
    I just tried putting the new disk on and if I was to tighten the hub nut up it clamps the disk too near the hub and rubs on it therefor locking it up so a spacer is definitely needed as just 1mm will bring the new disk away from the hub far enough so it doesn't rub.
    I just can't figure it out how the old discs fitted and worked fine. :/
  9. #9
    Join Date
    Aug 2010
    Location
    Corwen, North Wales
    Posts
    923
    Car
    My axle is off the car at the moment. I'll have a look this afternoon if it looks the same for you
  10. #10
    South East (Medway)
    Join Date
    Mar 2011
    Location
    Medway Kent
    Posts
    3,428
    Car
    BlackGold 182
    you are missing one, pm west renault i just bought one off him for £7 as mine got lost lol
  11. #11
    Quote Originally Posted by v16daf View Post
    That would be awesome if you could,
  12. #12
    Quote Originally Posted by Kieran.. View Post
    I take you were in the same scenario as me!
    I pm'd westrenault yesterday after trolling trolling through the archives. Still awaiting a relpy.
  13. #13
    South East (Medway)
    Join Date
    Mar 2011
    Location
    Medway Kent
    Posts
    3,428
    Car
    BlackGold 182
    lol well sort of was, i removed my disc, then this bloke stopped and asked if i was throwing the disc, i said yea and he took it, was only when i got to other side i realised i forgot to take the little spacer off the disc! lol
  14. #14
    ClioSport Trader
    Join Date
    Jan 2002
    Location
    Birmingham
    Posts
    48,458
    Car
    DO NOT PM, CALL!
    that looks like part is stuck to the stub still, CHECK it properly, put a better pic up, looks wrong to me
  15. #15
    Trust me it isn't stuck on the stub still. It may just look like it as I have cleaned it to see whats what.
  16. #16
    Join Date
    Aug 2003
    Location
    Brighouse West Yorkshire / Wigan North West
    Posts
    4,649
    Car
    williamsclio.co.uk/forum
    Yes.
    Without the washer / spacer behind the disk the bearing will wobble when torqued up. Dont run the car without the washer / spacer in as the wobble will take out your ABS Sensor.
    I have a washer if anyone needs one.
  17. #17
    I'm getting two sent to me today hopefully to receive them tomorrow.
  18. #18
    South East (Medway)
    Join Date
    Mar 2011
    Location
    Medway Kent
    Posts
    3,428
    Car
    BlackGold 182
    yeaa defiantly missing, i replaced mine yesterday, getting the disc off was a c**t so left the hub nut on a little bit, stuck the wheel back on and kicked the wheel from behind, soon came off lol
  19. #19
    Mine were bit of a bugger to get the old discs off too. Managed to find a sweet spot with a crow bar and they both just popped off nicely. When they wouldnt budge I thought, oh here we go..... Bent stub axle and can't remove disk to change stub axle either but all was good! Should receive mine today and get the car back on the road
  20. #20
    Join Date
    Jul 2007
    Location
    Ilkley, Leeds
    Posts
    3,810
    Car
    FF-Racing 182
    Does anyone on here have a picture of the washer/spacer? Would be much appreciated as I'm confused as to what i've taken off
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
pictures of renault clio stub axles
clio stub axle spacer collapsed
rear axle stub spacer missing
stub axle clio 2
stub axle clio
clio 182 re axle
clio 172 rear hub washers
renault stub axle
182 huvb washer
clio 172 back stub axle
clio cup rear stub axle
washer spacer rear hub
clio rear stub
clio 172 how to change rear stub axle
rear disc with spacer in it clio 172
clio sport 172 rear disc washer before hub nut
renault clio rear stub axle washer
clio 182 rear stub axle washer
172 cup axle
rear disc clio sport
brake axle washer
cliosport disc washer
whats the washer behind a Clio 182 disc
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
