Results 1 to 14 of 14
  1. #1
    North West
    Join Date
    Aug 2011
    Location
    South Manchester
    Posts
    4,357
    Car
    [O==[]==O]
    Coolant for a Clio 182?
    Right, someone said to me that the 182's use a different coolant to the usual stuff you can buy from Halfords ect..
    Can I just use anything? Or is there a specific type I should use?
  2. #2
    Join Date
    Jun 2010
    Location
    Liverpool
    Posts
    245
    Car
    BG PH1 Megane 225
    Re: Coolant for a Clio 182?
    Renault Type D coolant is what you'll need. You can get 5 litres of it direct from Renault for about £12ish or online. 5 litres is enough for a coolant change as I had some left over when I did mine
    http://renaultpartsdirect.co.uk/prod...-D-(5LTR).html
  3. #3
    Forum User
    Join Date
    Feb 2008
    Location
    N Yorkshire
    Posts
    2,008
    Car
    Dodgy one
    You want 2 5lt bottles to do it properly
  4. #4
    Join Date
    Oct 2010
    Location
    Devon
    Posts
    4,598
    Car
    Fiesta ST
    As said Renault type D.
  5. #5
    North West
    Join Date
    Aug 2011
    Location
    South Manchester
    Posts
    4,357
    Car
    [O==[]==O]
    I'm just changing the thermostat, so I'm not doing a complete change, just will need to top it up. I'll go to Renault tomorrow, if they're open!
  6. #6
    North West
    Join Date
    Aug 2011
    Location
    South Manchester
    Posts
    4,357
    Car
    [O==[]==O]
    Renault are closed tomorrow, deffo Type D that I need? Halfords dont do it do they?
  7. #7
    Join Date
    Aug 2010
    Location
    Midlands
    Posts
    5,149
    Car
    TCR'd 182
    yep definitely type d needed
  8. #8
    Planning on changing my coolant too, just wondering why this certain type of coolant is needed rather than just any coolant from Halfords or a local shop. Can anyone shed any light?
  9. #9
    Forum User
    Join Date
    Mar 2008
    Location
    felixstowe
    Posts
    1,297
    Car
    Renault Clio 172 ph1
    Its becuase renault reccomend it, its probably to do with the agents in it that protect water ways and stuff like that, some coolant will eat away at metals
  10. #10
    They recommend you run it on 98ron too but 95 is fine. Is it the same sort of thing with this, or are people really against using anything but the proper stuff with coolant?
    Genuine question btw so I know my options need to get it done over the weekend so may struggle getting the Renault stuff!
  11. #11
    Forum User
    Join Date
    Feb 2008
    Location
    N Yorkshire
    Posts
    2,008
    Car
    Dodgy one
    At £12 its pointless putting anything else in, the red halfords stiff is equivilant to renaults supposedly, i would run that if it was a cheap car,
  12. #12
    As said though I really have time to be waiting for the Renault stuff if they don't have it in stock... need to do the coolant flush over the weekend to use the car for Monday, which gives me... today! If needs be though I'll just wait for the Renault stuff. Just wondering what the differences were cheers.
  13. #13
    ClioSport Trader
    Join Date
    Oct 2005
    Location
    Nottingham
    Posts
    4,131
    Car
    Ex-BTCC R19 16v
    Type-D is a description of the mixture and intended temperature protection range not an actual product name. You need an ethelyn glycol based anti-freeze mixed with water to give protection to -23 degrees. It comes in all different colours do don't be put off by the pretty fluids but never mix brands or colours and never put neat glycol based AF into the system.
    We recommend and use the Renault per-mix for two reasons. Firstly, and the most important, price as its cheap then secondly ease of use. No faffing around with a hydrometer to make sure you've got the correct mix ratio... Just open, pour and you're done.
    Mick
    Diamond Motors
  14. #14
    Excellent Mick, thanks for that. I'll hold out until I can get some of the Renault stuff then
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
clio 172 coolant
clio 182 coolant
renault type d coolant
what coolant is needed for clio 172
clio 172 antifreeze
renault antifreeze type d
clio 172 coolant halfords
clio change coolant 182refilling coolant clio 182what is the coolant capacity of clio 182renault clio antifreezeclio coolantwhat coolant for clio 182coolant cliosport.netwhat do you put in the coolant bottle in a clioclio mk2 cooling system schematicrenault clio red coloured coolant in bottlehttp:www.cliosport.netforumshowthread.php639568-Coolant-for-a-Clio-182changing coolant in clio 182clio 172 coolant toprenault clio coolantrenault type d antifreezecan you mix different color coolants cliocoolant for clio 172clio 182 coolant changewhat coolant renault clio 172coolant clio 182guide to changing coolant on clio 182clio 182 low on collantRenault clio 182 What coolant cliosport.net coolant for clio 172clio 182 antifreezetype d renault coolantclio 182 anti freezeantifreeze colour for clio 182clio 182 changing coolantclio mk2 01 antifreezeclio 182 coolant colourcliosport antifreezerenault coolant type dwhat happens if you dont renault type d coolant in a cliosport 182can you use any coolant in clio 172clio 182 coolantchangeclio 172 coolant coloyrclio 182 red coolantwhich coolant clio 172coolant for 182 cliocliosport.net type d coolant antifreezerenault clio mk2 anti freeze cliosport.net cliosport coolant
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
