Page 1 of 13 1 2 3 11 ... LastLast
Results 1 to 20 of 255
  1. #1
    Forum User
    Join Date
    Oct 2006
    Location
    Posts
    1,549
    Car
    Track VTS
    Novice Saxo VTS Track car - Donny style
    So I bought Matthew's VTS - which was previously someone's on the 106owners forum's girlfriends or something. I've wanted to do track days for about 5 years, but never had the balls with my own daily use car + funds etc etc. When the baby was born, I thought it would never happen but my wife has suprisingly allowed it to happen (cheers love).
    Note: this is track day running on a budget.
    Here it is the day I picked it up:
    75k, lowered on Gmax springs at the front, torsion bar at the rear. Filter and exhaust also. Few dings and scars but nothing amazing to report. The car is solid underneath, a little cosmetically unclean but no problem.
    I basically drove it home and parked it up and today was the only time to start getting a list together (which then turned into doing stuff - as you do)...
    First thing was to sort the basics. The car needs to be road worthy and if something isn't right, It just pi$$es me off to the point I have to sort it anyway. I'll be stripping it and keeping all the parts - but before all that I cracked on with the basics I could do in 60 mins.
    The nearside headlight was knocking. I had a look and found this:
    Note: large washer, but still cracked plastic bracket.
    Home made top bracket FTL.
    I've removed the headlight and ordered a new one.
    Looks like someone has nudged something with the bonnet and thus it's broken the light brackets.
    Bit of panel beating:
    It doesn't rest on the light now at least. One job done.
    Next, the ECU cover...
    It wasn't fitting right and rattling away, so much so its started to rub through some cables.
    And rubbing on the bulkhead as pictured too.
    Cable protection restored and made my own bracket adjustments so it fits snug with no rattles.
    Next up was the air filter and cam breather...
    Home made cam breather - oh dear. YES that is wirewool and a bottle top.
    Whipped that off and the air filter. Will probably end up saving for a simota intake but have ordered a generic 19mm breather to go on for now.
    Cleaned the throttle body whilst I was there too.
    The previous owners had a sub, head unit, upgraded tweeters and door speakers. So whipped them all out as well (ebay). Found that the sub's power lead went under the car and in through the bottom of the passenger footwell then under the carpet to the boot.
    Whilst I was pulling the cables through I found these under the back seat.
    Technically by removing them I have gained £5 off No7 makeup (at boots) and saved 0.01grams on the track car kerb weight. The car parts receipt shows spark plugs and oil were done in 2011 - so that saves me doing them - will still check the quality later though, before her first outing.
    Next up was the bodykit. Its not sitting right on the passenger side arch/side skirt and doesn't sit right on either side rear section of the side skirts.
    Took the arch one off to find that all of the clips had broken and that it was actually tie-wrapped on the underside of the car.
    Ordered the repair kit from Citroen, so they'll sit back nicely.
    Guilty items: The metal bracket should actually be on the inside of the kit, but it has corroded and was just vibrating on the wing.
    This is the driver side rear section of the side skirt. You can just see the white clip, which is broken.
    That was it for today. Only had an hour.
    Parts ordered from Ebay and the first stage will be complete at the weekend.
    The next jobs (next week):
    - Tracking
    - New Brake Fluid
    - Check plugs and oil
    - Check coolant
    - Check exhaust hangers
    - New Discs and pads
    - Check and tighten gear linkage - a bit of a mixing bowl atm.
    - Stage 1 interior removal (+ spare wheel/cage)
    - Spend the £5 voucher on some new blusher
  2. #2
    Join Date
    Nov 2011
    Location
    Somerset
    Posts
    576
    Car
    Clio 182
    Re: Novice Saxo VTS Track car - Donny style
    Great start, you will have loads of fun with it on track once done!
  3. #3
    Join Date
    Aug 2009
    Location
    Yorkshire
    Posts
    4,533
    Car
    Golf GTI
    That oil filter!!!!
    No way that's what was under there, propper job!
    In one day of ownership you noticed about 10 things I didn't mange to in 2 months!!!
    Get cracking on mate, I want a passenger ride at Elvington still
  4. #4
    Forum User
    Join Date
    Oct 2006
    Location
    Posts
    1,549
    Car
    Track VTS
    Quote Originally Posted by Matthew. View Post
    That oil filter!!!!
    I did LOL at the filter mate - thought you'd like it. Even more so when I jacked it up (after parking it on some wood! damn this thing is lowz) and noticed the NSF wing body kit was completely held on by a cable tie pulling it underneath.
    Just need to get a full day on it and she'll be ready - just finding the time, what with working and the young un.
    You got a helmet? bring it along if so - passenger rides are for taxi's mate, you can take the wheel.
  5. #5
    ClioSport Senior Moderator
    Join Date
    May 2008
    Location
    Crewe
    Posts
    10,314
    Car
    JDM y0
    clio projects? Not clear enough huh
    Looks good though, always like the saxo vts
  6. #6
    Join Date
    Aug 2009
    Location
    Yorkshire
    Posts
    4,533
    Car
    Golf GTI
    Quote Originally Posted by Doncaster _K9 View Post
    Cant beleive anyone would use wire wool and a bottle top for a filter though, must be a £5 part!?!
    I took it to a place in Huddersfield for the tracking when I got it, they wouldn't do it due to being too low!
    The joys of mega, and I do mean mega, handling!!
    Yeah got a helmet mate, sounds good to me!!
  7. #7
    Forum User
    Join Date
    Apr 2011
    Location
    Lancaster
    Posts
    35
    Car
    Mk3 DynTT 1.2TCE
    Was this Martin's (Marvvv) girlfriends vts?
  8. #8
    Forum User
    Join Date
    Oct 2008
    Location
    Yorkshire
    Posts
    2,072
    Car
    Adidas LAs
    I don't think I would have tracked this one! 3 plug iirc? and Slooow I hope to god Marv didn't do those bodges!
  9. #9
    Forum User
    Join Date
    Oct 2006
    Location
    Posts
    1,549
    Car
    Track VTS
    Quote Originally Posted by X200LOL View Post
    If she was called Lisa, then it could be.
    Don't tell them though, I want the £5 voucher.
  10. #10
    Forum User
    Join Date
    Oct 2006
    Location
    Posts
    1,549
    Car
    Track VTS
    Quote Originally Posted by MarcoB View Post
    huh?
  11. #11
    Forum User
    Join Date
    Apr 2011
    Location
    Lancaster
    Posts
    35
    Car
    Mk3 DynTT 1.2TCE
    Yes she is. Thought I recognised the plates. I look forward to seeing how this goes
  12. #12
    Forum User
    Join Date
    Oct 2010
    Location
    Pontefract
    Posts
    1,909
    Car
    Integra DC2
    Saxo VTS' are ftw. Subscribed!
  13. #13
    Forum User
    Join Date
    Nov 2005
    Location
    Mansfield, Notts
    Posts
    2,074
    Car
    330ci M Coupe, Z750
    3 plug isn't a problem unless you're going to start messing with ITB's or boost. He said budget track day car so i doubt either of those are on his agenda.
  14. #14
    Join Date
    Jul 2005
    Posts
    32,279
    Car
    Lost Count
    Whats everyone on about 3 plug?!
  15. #15
    Forum User
    Join Date
    Oct 2006
    Location
    Posts
    1,549
    Car
    Track VTS
    Quote Originally Posted by ch!ppen View Post
    Correct bud, donny is the poverty capital of the north, this is a budget spec machine.
  16. #16
    Forum User
    Join Date
    Oct 2006
    Location
    Posts
    1,549
    Car
    Track VTS
    Quote Originally Posted by Daniel View Post
    I think it's the ecu. This one has 3 plugs and the earlier (?) have single plug and are meant to be easier to tune or replace (?).
  17. #17
    Join Date
    Jan 2007
    Location
    Fridays on CS are back.
    Posts
    7,283
    Car
    [OO==[][]==OO]
    The engine loom has three plugs, rather than just one. Came on the later 106 GTi's/VTS'.
    Doesn't make a huge difference really if going for new ITB's/mods, but most of the second hand bits kicking about are based around a single plug ECU/Loom..
  18. #18
    Join Date
    Sep 2005
    Location
    Failsport HQ.
    Posts
    11,705
    Car
    :R32 For Sale
    Will keep an eye on this!! Saxo's are most definately FTW
    If you need some ideas, check out my Shed thread: http://www.cliosport.net/forum/showt...ect-Track-Shed Everything (inc. the car) cost less than £2.5 and that was built to a very decent track/fast road spec - all the bits that were fitted were best of breed.
  19. #19
    ClioSport Moderator +
    Area Rep South East
    Join Date
    Feb 2006
    Location
    Sidcup, SE London
    Posts
    14,385
    Car
    E85 Z4 3.0
    Good effort with this! Lovely car and it'll make a perfect track toy.
  20. #20
    Join Date
    Aug 2009
    Location
    Yorkshire
    Posts
    4,533
    Car
    Golf GTI
    Yeah this used to be Marvvv's old car, and his girlfriends before he owned it.
    I had it, circa 3 months and it ran like a dream.
    Its the 1st car I have owned without having any problems to fix (the irony its a 12 year old French tin can too)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
saxo vts track car
saxo vts track projectsaxo vts ıtb106 gti CAMS pulleysaxo com itbs AT Powerchange camshaft saxo vtssaxo vts trackstripped out saxo vtssaxo vts track car buildsaxo vts strippedsaxo vtr track carscams saxo cup172 throttle body on vtssaxo track dayhow to prepare saxo vtr for tracksaxo track modssaxo cat camstrack carmaking a saxo vts track carsaxo track car projectbilstein for clio 16s vs sax0 vtssaxo making a novicesaxo vts track competitionsaxo vts shedhow much would it cost to tune my saxo vtsoem clutch saxo vtrtracked saxosaxo vts missfire when jacked upsaxo kit car buildhow to make a saxo track cartips for preparing saxo vtr for the tracksaxo vts breather modsmaking a vtr a track carhow to track auto partshow to change cams saxo vtsitb s saxo kit carbattery relocation saxo vtssaxo vtr kent cam needs a remapwots the best oil breather filter for vtsmaking a saxo a track carsaxo vts rear end loweredwill 306 cyclones rub on a saxosaxo vts what track suspensionsaxo track car buildsaxo car modifications required for track dayssaxo vts crank saxo vts on the track saxo track partsbuildimg a saxo vtssaxo vts carbon
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
