Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 53
  1. #1
    Forum User
    Join Date
    Apr 2012
    Location
    nr Bristol
    Posts
    179
    Rattle, well theres a surprise!
    Morning, I bought a 172 cup a week ago, not a bad little car tbh - strange having to rev it quite a bit as am used to a 1.8T, and VAG build quality, I can deal with the odd rattle inside, but one on the outside is doing my head in.
    Have been under the car prodding and pulling on things, cant replicate the noise so dont know how to fix, any clues?
    The noise - "rattle" is the best word to describe it, cant hear it with windows closed, but with drivers window open you can hear it faintly just driving along normally, which I presume is just through the car vibrating, now when you hit bumps on our crap roads is where it is at its worst, much more obvious. It sound just as if there is a washer or something bouncing up and down/ wobbling about, metal on metal but not damaging, just lose if that makes sense, but where?
    I've done a search and had a browse on people saying heat sheilds, but as I say from being underneath shaking stuff, I cant replicate the sound to fix it? Key points to check/ how to check. Oh and I've tried rocking the car to get the rattle, no luck..
    HELP?!
  2. #2
    ClioSport Trader
    Join Date
    Aug 2011
    Location
    Bedford
    Posts
    5,727
    Car
    DON'T SEND ME PM'S!!
    Re: Rattle, well theres a surprise!
    balljoint?
  3. #3
    Forum User
    Join Date
    Apr 2012
    Location
    nr Bristol
    Posts
    179
    Pretty sure the noise if from the rear, but will get looking around the front too this weekend
  4. #4
    Join Date
    Jan 2011
    Location
    Inverness
    Posts
    2,920
    Car
    Iceberg 172
    Not your exhaust is it? Maybe your rubber in the mount is buggered and its metal on metal?
  5. #5
    Join Date
    Oct 2011
    Location
    Plymouth
    Posts
    1,773
    Car
    PB Clio 172
    Sound like exhaust to me ! exhaust on these cars isnt the best...
  6. #6
    Forum User
    Join Date
    Apr 2012
    Location
    nr Bristol
    Posts
    179
    Quote Originally Posted by RSIceberg View Post
    Gave that a good pull side to side and up and down, nothing.
    Definately sounds like a little piece of metal almost bouncing/ rattle, rather than a knocking. If that makes sense lol.
  7. #7
    Exhaust heatshield? Mine didnt look like it was touching but it used to when the exhaust was hot. Fixed with some washers.
  8. #8
    Forum User
    Join Date
    Apr 2012
    Location
    nr Bristol
    Posts
    179
    Quote Originally Posted by Akay View Post
    This is what I've kept reading but I cant replicate the noise to find out, It would make sense as the tinny looking heatshield would make the right noise.
    Washers you say, where am I fixing these washers? Between the heatshield and the car, or the heatshield and exhuast
  9. #9
    Forum User
    Join Date
    Nov 2007
    Location
    Dundee
    Posts
    735
    Car
    172 and vw passat
    I have the exact same problem and its Deffo the same noise I'm getting. I replaced my exhaust hangers but it wasn't that. When you drive with the door open it sounds like its coming from rear drivers side wheel but iv done the same had the car jacked up and can't find anything. I do have a heat sheild hanging but rattling that off my exhaust dosnt make the same noise.
  10. #10
    Forum User
    Join Date
    Apr 2012
    Location
    nr Bristol
    Posts
    179
    Quote Originally Posted by Dunx90 View Post
    Even though I cant hear your noise, I would say we're the same! I'm gonna hopefully stick it up on some ramps this weekend, if not gonna do some slow driving over some bumps in a car park with people looking and trying to find where the noise is from ha! I'll keep you informed if I solve it, well more like when I solve it as it must sound s**t when driving about.
  11. #11
    Join Date
    Sep 2010
    Location
    bromborough/wrexham
    Posts
    950
    Car
    rb182 cup
    i'd say exhaust bracket...thats welded to the backbox...mine was rattling for ages till it fell off
  12. #12
    Forum User
    Join Date
    Apr 2012
    Location
    nr Bristol
    Posts
    179
    I better find it and fix it or I'll be selling again soon lol.
    Crap video, and sounds more like a squeak here but definately a rattle.
    Certain it sounds from the right rear, I know I'm sat on the right hand side but just seems next, and behind me. But there is nothing on the right rear to rattle?!
  13. #13
    Forum User
    Join Date
    Apr 2011
    Location
    bournemouth
    Posts
    184
    Car
    pb ph2 172
    i to had and annoying rattle from the back
    it turned out the be the rear wiper motor had come loose
  14. #14
    Forum User
    Join Date
    Apr 2012
    Location
    nr Bristol
    Posts
    179
    Quote Originally Posted by bengtt5 View Post
    Will get the trim off and give that a check too even thought it sounds external, this car is going to be rebuilt by me to cure it lol
  15. #15
    Forum User
    Join Date
    Apr 2012
    Location
    nr Bristol
    Posts
    179
    Boot shook as much as I can without ripping it off - negative
    Exhaust mount changed - negative
    Getting severely pissed off - affirmative
    More descriptive of the noise, sounds exactly like keys being shook lightly, no its not my keys ha.
    I just can't figure it out, sounds like a washer bouncing around and rattling, a really light noise, nothing 'damaging' if that makes sense.
    Doest change with exhaust note, can knock it out of gear and still does it, when going over bumps, so it's vibration movement doing it.
    HELP!!
  16. #16
    Join Date
    May 2011
    Location
    Cornwall
    Posts
    65
    Car
    Clio mk2 172
    try the rear boot latch. I had a rattle and I searched high and low and it turned out to be this!
  17. #17
    Taken the rear seats out and checked to see if theres anything underneath them, like maybe coins?
    I think what i said's a long shot... but its worth a try and only takes a sec to have them out!
  18. #18
    Forum User
    Join Date
    Apr 2012
    Location
    nr Bristol
    Posts
    179
    Seats will be out this weekend then, 99.9% it's in the boot.
    Certain it's under the car but checking everything and anything.
    Found this thread, but no solution
    http://www.cliosport.net/forum/showt...-noise-at-rear
  19. #19
    Join Date
    Oct 2009
    Location
    Newcastle
    Posts
    1,134
    Car
    Tit PH1 + Flamer PH2
    I had a rattle coming from the boot mechanism, bit of a PITA but perhaps stick a trusting friend in the boot to help identify.
  20. #20
    Forum User
    Join Date
    Apr 2012
    Location
    nr Bristol
    Posts
    179
    Oh and ONLY hear it when windows are open.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
site:cliosport.net how to fix clio 182 collapsed exhaust mount
Rattlewell
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
