Results 1 to 9 of 9
  1. #1
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    534
    Car
    mk2 ph2 1.2 16v
    Passenger seat airbag and rear seatbelt issues, help please
    Last month i hit a kerb rather hard, blowing out 2 tyres and setting off the passenger seat side airbag. Since replacing the tyres and broken wheel i just tucked the airbag back into the seat as a temporary measure until i found another seat. Does anyone know where I could find a cheap seat that would match the pattern design of my car? Also the seat belt pretensioner has snapped at the bottom but still works fine. The rear passenger seat on the left's seatbelt has completely jammed too. Airbag warning light is on, is there any way to disable this? will it just turn off if i replace the seat?
  2. #2
    Forum User
    Join Date
    Feb 2012
    Posts
    10
    Car
    Clio 182 Arctic Blue
    Re: Passenger seat airbag and rear seatbelt issues, help please
    i have the exact same problem, fixed the seatbelt, wheel etc. but have the airbag just pushed back in. want to know how easy it is to sort these lights and how much its gonna cost :/
  3. #3
    Forum User
    Join Date
    May 2008
    Location
    Essex
    Posts
    305
    Car
    Clio 197 08
    All activated parts will need replacing, ensure to get this professionally or make sure battery has been disconnected from the car for ten minutes
    The airbag ecu will have a crash code stored in them. U can either take this out yourself and send it to a company off eBay to erase the crash code or go into Renault and they will tell you that you need a new ecu for mega bucks £££££
  4. #4
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    534
    Car
    mk2 ph2 1.2 16v
    How did you fix the seatbelt? I've seen someone on eBay who resets the ECU for £30, which would turn off the light
  5. #5
    Forum User
    Join Date
    Feb 2008
    Location
    Essix!!
    Posts
    4,215
    Car
    Ph1 track 172
    i could sell you a new airbag ECU for £20 posted
    go to a strap yard for the seat and hope to find one thats not gone off.
    all the safety equiptment is not designed to be actived more than once so personally id pick up new pretensioners, seatbelts if you want to retain the safety features of the car!!
  6. #6
    Join Date
    Nov 2010
    Location
    Chichester, W. Sussex
    Posts
    385
    Car
    V6 Ph2 & 172 Ph1
    I've got 2 front seats out of a 172 ph1 for sale at the moment. See here : http://www.cliosport.net/forum/showt...de-Front-Seats
    Could be a nice upgrade for you.
  7. #7
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    534
    Car
    mk2 ph2 1.2 16v
    Struggler I'll get back to you on that, see where i stand after getting the new seat etc. Thanks for the offer
  8. #8
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    534
    Car
    mk2 ph2 1.2 16v
    benkay it won't let me see the link you posted, most probably because i'm not a full member yet, how much are you selling them for? Thanks
  9. #9
    Join Date
    Mar 2012
    Location
    Bristol
    Posts
    534
    Car
    mk2 ph2 1.2 16v
    Getting a new front seat (finally) anyone know if i'd be able to fit it myself or will it need doing professionally? Do i have to replace ECU before replacing the seat? Finally how would I go about replacing the rear seatbelt which has locked up?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
Clio passenger seatbelt
replacing seat belt on clio
clio passenger seat wont slide back
clio passenger sear airbag
is it costly to replace an ecu and seatbelt pretensioners
clio 197 airbag ecu
clio disarm passenger airbag fault light
can you temporarily turn clio airbag light off
cliosport.net wheres airbag sensor on clio 182
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
