Re: 2200 miles and its going into the dealership already!
Sounds like its well on its way to being sorted then mate
Christ missed this first time round - kinda puts me off my next plan after the meg and getting a brand spanker.
Second hand FTW!
Did they see that the subframe was under strain?
I've just read through the whole thread. What absolutely horrendous customer service for a returning customer. It often seems with companies that you had to go a lot further than you should do just to receive what every customer should. I hope it is sorted once you get the tyres done!
My grandad had an issue with a Renault dealership, gearbox went on him 1.2 clio after 1400 miles.. AA came out to take the car to the dealership and for 8 days they refused to accept that the gearbox had gone even though the AA man told them it had... In the end they stripped it down and found that it was f'cked...
It's a real shame that all this has happened to you mate, I can't believe how unhelpful that dealership has been throughout the whole thing. I don't think I could have kept my cool about it for this long and that car would have been on fire on their forecourt weeks and weeks ago.
Good luck
heres the alignment report guys...
They said the subframe sits in locating dowels, so once its in, you cant get movement from it, so once Progrip got it sitting in properly, thats as much as you can do, so it still has that 4mm difference between the front wheels.
Everything is sitting within tollerance now which is why its all green but if you look at some of the figures they are at extreme ends of the tollerance side to side - could this cause issues?
should the car have that sort of difference in camber side to side? i assumed you would want it as close as possible to each other? or is this setup to stop it pulling to one side on cambered uk roads?
basically once the car has a pair of new front tyres on it ill take it a good test run and see if its fixed, arnold clark say they cant find out why its wore its n/s tyre so fast in the inside so are assuming its happened before the subframe was re aligned so now it should be fine, i guess since im not paying for the tyres then we will just need to wait and see. they also mentioned with the car not having an LSD and that side having the shortest driveshaft thats the wheel that will spin up most of the time, however ive very rarely ever had the car spin up during driving.
anyone got any thoughts on that report?
Regretting accepting a new engine yet?
Can you get them to stick another RS from the forecourt on the machine, see what readings that's giving?
yeah think its going for a megane 265 at the end of the month actually. after having a poke about one yesterday. going to book a test drive in the 265 demo that ness have.
Originally Posted by
AK
Computer says it's fine though.
AK
i suggested that but the renaultsport specialist dealer doesnt have one as a demo car, or for sale anywhere. neither a megane either! lol
Adam.
yep thats the issue as far as they are concerned its ok, now i dont know enough about suspension geometry to say if that can still cause the issue or not, id imagine on day to day road driving thats acceptable, (it drives fine daily) push on though and its dangerous.
also quick question, if the car is suffering from a sticking pad or something brake related, will a brake efficiency tester or what ever they call it that they use for MOT's show this up, as like i said around town the brakes feel fine no pulling, hard on the brakes approaching a roundabout etc it wanders about the road , mostly left but the brakes generally feel very weak when doing this, only thing i can compair it to is when you absolutely cook the brakes on a 172 and find yourself aproaching a roundabout with loads of brakefade, that weird feeling where you think, s**t im not stopping in time!
i genuinely feel like setting up a pettition and getting as many people i can who own clio 200's to drive this one and give an opinion on it! lol
Ok , surprised that the motorsport boys haven't been on here to give you some guidance but looking at the figures you have now i can't see an issue with it as a standard setup .
i would suggest the front tyres will make a difference to the braking stability , and what they have told you about it spinning up the shorter shaft ns wheel is correct .
can't see it won't drive fine now ....
yeah i understand the shorter shaft is always going to spin up first when launching but i dont launch it, and ive very rarely had it spin a wheel on exit of a corner either, however we will see how the next pair of tyres wear.
ill report back when the new tyres are on, probably friday morning and see where we go from there!
Martin_172
Yes the brake tester should show this up mate, as one side will have more pressure when you start to apply the brakes
Martin , there is always slightly more torque to the shorter shaft (of you have the effect of ) its why when a car torque steers it always pulls left first .
update, car came back from dealership with 2 new tyres driving pretty well, for about 3 days and now its back to its old tricks pulling left hard under braking and then it appears the EBD kicks in and trys to correct it but ends up over correcting it, take your hand of the steeringwheel, brake hard it dives left then the steeringwheel turns right and starts trying to correct, its like nightrider!
done 2 laps of knockhill and had to abandon it as it was that dangerous!
going into Ian Grieve Subaru on Wednesday for a look as they are very well respected about here and im finished with renault.
Martin--
Wouldnt it be better to get it ou there with a GO pro camera & film the problems whilst your driving?
then take the evidence to renault-
Also compare it like for like with another 200?
Steve
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Visitors found this page by searching for:
Nobody has landed on this page from an internet search engine.
Powered by
vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules:
Sphinx-based search
