Page 19 of 30 FirstFirst ... 9 17 18 19 20 21 29 ... LastLast
Results 361 to 380 of 583
  1. #361
    Join Date
    Sep 2005
    Location
    Derbyshire
    Posts
    10,135
    Car
    boost
    Re: Supercharged Sunflower + Forged Engine + Brembos + Recaros + 16" F1s
    Hopefully the charger gets sorted out for you.
    Congrats on the mag feature though
  2. #362
    Join Date
    Feb 2004
    Location
    Gill
    Posts
    15,465
    Car
    ITB172, DCi 80 Daily
    Quote Originally Posted by Craig Davis View Post
    Well as much as I'm gutted my car didn't make it to FCS I spoke to Davy Lewis of Performance French Cars while I was there & soon as I get a new charger sorted he's going to do a mag feature on it so I'm over the moon with that as that was my aim.
    good to hear that, i had mentioned the sunflower to dav in passing a little while ago,
    good to hear your gonna keep plugging too....
  3. #363
    Join Date
    Dec 2010
    Posts
    905
    Car
    Sunflower Ph1
    how you getting on with the charger mate?
    is this just really bad luck or are the seals a weak spot if yours is the 3rd to go (as reading above) im still very much between a charger or a MWM / Chip style turbo. either way just wish list at the moment
  4. #364
    Join Date
    Jun 2011
    Location
    Devizes, Wiltshire
    Posts
    399
    Car
    Phase 2 172 Sport
    Keep ya chin up mate, like you said its all part of modding a car. Car looks outstanding though I must say .
  5. #365
    Join Date
    Dec 2010
    Posts
    905
    Car
    Sunflower Ph1
    I still get inspired by reading this from the start again and again. Just wish I could start my project off but don't see it anytime soon unfortunately. Just doing few little bits here and there at moment
  6. #366
    Join Date
    Apr 2009
    Location
    NOT Eastwood
    Posts
    7,070
    Car
    Flower Power
    We need an update in here tbh
    Will it be sorted for CSS?
  7. #367
    Join Date
    Jan 2004
    Location
    DerbyShire
    Posts
    424
    Car
    Dimma, Williams, 182
    Looks like rotrex will be changing the seals on new production chargers at some point
    http://www.rotrex.com/Home/Technolog...nt_Update.aspx no effecting the c30 atm but maybe soon
    the main part being
    'Nevertheless it is always best to position the supercharger above the canister and oil cooler to avoid any risk of leakage in case of wear or damage to the high speed spindle seal.'
    so is the canister above the charger on these installs?
    Although it does state in the install guide 'Place the oil canister with the cap below or level with the supercharger’s shaft. Use the bracket supplied in the oil set. Make sure the canister is placed upright. Leave the plastic plugs in place to prevent debris from entering the system'
  8. #368
    Area Rep
    East Anglia
    Join Date
    Sep 2004
    Location
    Suffolk
    Posts
    10,682
    Car
    Monaco 172
    FFS, it sits right at the bottom on the Clio.
    Looks like that's not for the new seals and recommended on old ones. Going to have to rejig all mine by looks of things
  9. #369
    Join Date
    Dec 2010
    Posts
    905
    Car
    Sunflower Ph1
    So how low does the charger sit? From the pics ive seen it seems low. Is it possiblee to get both the cooler and canister actually lower? Surely the coolers are already low as reasonabley possible
  10. #370
    Area Rep
    East Anglia
    Join Date
    Sep 2004
    Location
    Suffolk
    Posts
    10,682
    Car
    Monaco 172
    I could get my cooler inline, I need to rearrange a few bits anyway
    You can see where the first blue hose goes to the cooler on my old one, it's basically same place now.
    It would be impossible to move the canister anywhere though?!
  11. #371
    Forum User
    Join Date
    Feb 2007
    Location
    Gloucester B-Spec Skunkworks
    Posts
    3,454
    Car
    Mazdarati Tank
    By luck, I had the cooler below the charger but god knows where you'd put the canister low enough :/
  12. #372
    Join Date
    Jan 2004
    Location
    DerbyShire
    Posts
    424
    Car
    so could be a cause of the premature failure on the seals, maybe with the canister above the SC you are causing some additonal presure and causing the blow.
    From reading stuff on hondas and beemers, they are running these c30 chargers for 50 to 70k miles with no issue...
    so does seam strange that on the clios they are failing....
    Although also if they are failing on the rollers maybe they are not getting good enough air flow to keep them cool....
    Whats the operational temp on the oil and is anyone monitoring this to make sure the cooling is sufficiant ?
  13. #373
    Join Date
    Jun 2009
    Location
    Cymru!
    Posts
    1,340
    Car
    172 CUP
    Strange to see the failures as the 306 boys have been running them fine for 4+ years and the only failure so far was due to a pinched oil feed pipe.my install is still going strong after 25k and 3 years
  14. #374
    Forum User
    Join Date
    May 2011
    Location
    Lichfield
    Posts
    63
    Car
    172 Hillclimb/Sprint
    Cracking build! Always expect setback's when doing this kind of thing, the way it goes pal!
  15. #375
    Join Date
    Jan 2004
    Location
    DerbyShire
    Posts
    424
    Car
    Anyone have a temp sensor running in the SC oil ?
    Just wondering, since they are passive cooled how do they hold up when sat idling ?? Or for example you get stuck in a jam on the m25 for a few hours..
  16. #376
    Join Date
    Jun 2012
    Location
    Fife , Scotland
    Posts
    315
    Would it not be possible to fit the oil cooler where Bomber has put his, then mount the oil tank in the wheel arch where the original carbon canister was.
    By mounting it low with a hole cut so the fill was sticking into the engine bay it would keep the tank level with the charger, give air flow to cool the oil.
  17. #377
    Join Date
    Nov 2011
    Posts
    2,073
    Car
    Clio 172
    Epic build, shame about the charger and I look forward to seeing it running.
  18. #378
    Forum User
    Join Date
    Feb 2007
    Location
    Posts
    3,454
    Car
    Mazdarati Tank
    dont think many/any used oil temp sensor in the SC fluid.
    Neil, thats actually a pretty good idea, so long as it was still being run with arch liners as they are quite delicate as a whole. Although it would still need easy access as they need checking regularly
  19. #379
    Join Date
    Feb 2006
    Location
    Durham
    Posts
    5,008
    Car
    Trophy #64
    apparently its just being ran in as we speak, just needs a few more miles on it then it can go for its propper map its got a base map on atm according to one of craigs mates, which will be 200+
  20. #380
    Join Date
    Nov 2011
    Location
    Somerset / London
    Posts
    14,090
    Car
    CLIO RS2/ Turbo/Mk1
    Glad to hear its up and running.
    CSS?
Similar Threads
  1. Audi S3 8L Forged engine new turbo still in warranty - will swap for 182
    By rob_sri in forum eBay, Pistonheads, & Autotrader
    Last Post: 24-01-2011, 23:07
  2. 172 or 182 manifold....Forged engine + ITB's
    By Barron in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 01-02-2010, 07:43
  3. Chances of putting supercharged type-r engine in clio
    By lusty v-tec in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 16-04-2009, 10:36
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
clio 172 rotrex
clio sport sunflower
clio sport ph1
clio ph1
rotrex porsche
powered by myBB sunflower floral decoration ideas
clio sport black gold rob_sri
Paul @RS Tuning
rotrex supercharger clio
clio 172 ph1 dark headlights
Sport Clio rotrex
i3 supercharged engine
k tec racing supercharged clio 200
clio 172 iceberg
site:cliosport.net clio air con pipe leak
speckys corsaru
cliosport craig davis
rotrex f4r
carbon canister clio mk1 can it be taken off
renault clio rs paulrs
clio rs ph1 sunflower yellow
clio 172 which is better ITBs or supercharged
cliosport.net radiator hose kit 172 cliosport
powered by myBB exterior paint brands
clio RS forged engine
supercharged clio 182 for sale
site:cliosport.net clio rs 1 yellow sunflower
how much is clio sport worth with forged engine and cams
clio 182 with eaton supercharger kit
eaton supercharger bracket clio 182
clio 172 oz racing
yellow 172 supercharged clio
clio brembos
yellow 172 supervharged clio
how to fit a supercharger 172
clio RS rotrex
how much for itbs and ecu fitted to cliosport
site:cliosport.net supercharged clio 1.2
super charged clio 182
clio supercharged cliosport
rotrex supercharger clio sport
clio 172 ph1 rear
clio sport 172 engine COOLANT HOSE
type r or Clio sport with itbs
clio 16s scuttle kit
craig davis clio
megane f4r with 182 clio intake
forged supercharged clio
yellow supercharged clio
sunflower yellow clio 172
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
