Page 1 of 2 1 2 LastLast
Results 1 to 20 of 25
  1. #1
    Forum User
    Join Date
    Feb 2012
    Location
    High Wycombe
    Posts
    8
    Car
    Clio182
    Clio 182 Exhaust Gas Monitor Warning Light
    Hi everyone,
    I know this has come up a few times on here but I bought a late 04 182 yesterday and this warning light came on. Many people have been saying that it could be the lambda sensor or the cat needs replacing but has any heard that it could possibly be a coil?
    As I have never driven a 182 before I'm not sure if its down on power as I have nothing to compare it to but I'm getting about 34 mpg whilst doing about 80 on the motorway, don't know if that helps.
    Hope someone can help!
    Romano
  2. #2
    Join Date
    Aug 2008
    Location
    Farnborough, Hampshire
    Posts
    2,258
    Car
    Liquid Yellow 182 FF
    Re: Clio 182 Exhaust Gas Monitor Warning Light
    What fuel did you put in it? They can come on if you use normal unleaded.
  3. #3
    Forum User
    Join Date
    Feb 2012
    Location
    High Wycombe
    Posts
    8
    Car
    Clio182
    Yeah I filled it up with normal unleaded on the way back from getting it. What fuel do you recommend?
  4. #4
    Forum User
    Join Date
    Sep 2011
    Location
    Tonbridge , Kent
    Posts
    536
    Car
    Ph1 172
    Quote Originally Posted by Romano View Post
    98 Ron (V-Power)
    Or any other premium unleaded
  5. #5
    Forum User
    Join Date
    Feb 2012
    Location
    High Wycombe
    Posts
    8
    Car
    Clio182
    Ok thanks. I don't understand why that would cause it to come on considering standard unleaded is what the manual recommends anyway??
  6. #6
    Join Date
    Aug 2008
    Location
    Posts
    2,258
    Car
    Mines always been run on V-power (98 Ron) I stuck normal unleaded in the other day and it came on, ive since gone back to 98 and its fine.
  7. #7
    Forum User
    Join Date
    Feb 2012
    Location
    High Wycombe
    Posts
    8
    Car
    Clio182
    Oh right ok well that makes sense as the guy who owned it before me was only putting vpower in it. Thanks for your help
  8. #8
    ClioSport Senior Moderator
    Join Date
    May 2008
    Location
    Crewe
    Posts
    10,314
    Car
    JDM y0
    They run fine on 95RON
  9. #9
    Forum User
    Join Date
    Feb 2012
    Location
    High Wycombe
    Posts
    8
    Car
    Clio182
    Do you think its not that I put 95 in then? Do you think it could be that because it has been running on 98 its a temporary glitch?
  10. #10
    Join Date
    May 2008
    Location
    Crewe
    Posts
    10,314
    Car
    JDM y0
    Its difficult to say tbh. Best waiting for a specialist to come along.
    But IMO to say its because you're not running it on v-power is just silly, its a clio not a ferarri and the vpower wont make much if at all difference tbh.
    Get it plugged into a diagnostic tool thats the only way to 100% check whats wrong.
  11. #11
    Forum User
    Join Date
    Feb 2012
    Location
    High Wycombe
    Posts
    8
    Car
    Clio182
    Yeah thats what I was thinking. Have you ever heard it being a problem with the coils?
  12. #12
    Join Date
    May 2008
    Location
    Crewe
    Posts
    10,314
    Car
    JDM y0
    they have a coil pack, leads and plugs.
    If it was coil pack you might notice with it mis firing etc. Lambda sounds like a good place to start, but its a guessing game until you get it plugged in
  13. #13
    Forum User
    Join Date
    Feb 2012
    Location
    High Wycombe
    Posts
    8
    Car
    Clio182
    OK cheers i'll have to get it checked
  14. #14
    Forum User
    Join Date
    Apr 2012
    Location
    sheffield
    Posts
    24
    Car
    Clio Sport 2.0 16v
    Im new to the site, & recently purchased a Clio 182 - I'm sure I used the premium unleaded (97 - not 98), would this be the reason my light has come on ?
    Or could anyone shed any light in my direction on what could be causing it. I know you've mentioned a OBD (on board diagnostic) but where can I get this done - where it isn't going to cost a fortune - cheers
  15. #15
    Forum User
    Join Date
    Feb 2012
    Location
    High Wycombe
    Posts
    8
    Car
    Clio182
    i dont know if it would be down to petrol seems unlikely to me. i had it checked at kwik fit and it was the post lambda sensor which was faulty so had to get that changed which was £100.00 fitted (not by them, i got it fitted somewhere else). what you could do is get it plugged in and get them to turn the light off and see if comes back on after, that way you definitely know its faulty. getting it checked usually costs around £25.00 i could've find a price any cheaper than that! hope this helps
  16. #16
    Forum User
    Join Date
    Apr 2012
    Location
    sheffield
    Posts
    24
    Car
    Clio Sport 2.0 16v
    That seems a lot of money, which I don't fancy paying.
    Guessing I'm going to have to get it looked at
    Cheers fella
  17. #17
    Forum User
    Join Date
    Mar 2012
    Posts
    144
    Car
    clio 182FF
    I personally dont think the petrol would make any difference, i havent had my 182 long but the previous owner ran it on premium fuel only. I intended to do the same but came to a garage which didnt stock it, i put the 95 standard in, a few days later i had a emissions light. Put v power in it on my next fill up and not long after it went again.
    Like i said i agree with the guy who mentions its no ferrari or anything and i doubt there is a missive difference but its strange that the light came on at the same time the fuel changed.... It is important to not i had also just fixed my manifold to cat joint as this was blowing abit so this could have been the contributing factor but who knows. Maybe fill it up with some v power and drive it around abit and see if the light comes off after atleast 50 plus miles, if not then i guess that isnt the problem!
  18. #18
    Forum User
    Join Date
    Apr 2012
    Location
    sheffield
    Posts
    24
    Car
    Clio Sport 2.0 16v
    Cheers Lucky - I'll try it.
    Will let you know what I find, V Power 98 yeah?
    Cheers Romano also
  19. #19
    Forum User
    Join Date
    Apr 2012
    Location
    sheffield
    Posts
    24
    Car
    Clio Sport 2.0 16v
    Forgot to add, I started my car up yesterday afternoon, & noticed something missing.... The light has gone off.
    Which is good news, but I'm taking it to a garage to get looked over (as Im having the Cambelt changed, Aux belt changed & Water pump), so i'll let them check it over
    Cheers again for the help guys
  20. #20
    My EML came back on after haiving it reset. Need to try some V-Power as well
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
clio warning lights diagram
exhaust gas monitor warning light clio 182
clio 182 exhaust gas warning light
clio warning lights
clio 182 warning lights
exhaust monitor light clio
light on dash came on clio 182 sport
clio warning light
exhaust gas monitor light
clio exhaust manifold sensor
site:cliosport.net renault emissions warning lightclio sport 182 gas warning lightclio sport warning light coolant 182hart warning light on clio 182 dashclio 182 dashboard lightsexhaust gas monitor warning light clio shudderingrenault clio exhaust monitor lightcoil warning lights opn dash of renault cliorenault water in fuel warnong clio light possible causeclio182 exhaust gas monitor warning lightexhaust gas emission warning light causerenault clio exhaust gas monitor burning smellclio 2 warning light exhaustcan condensation cause water in fuel light to come on in renault cliorenault clio 2.0 exhaust warning lightdash lights on clio exhaust emissionsgas emission warning light renault clio exhaust gas monitor warning light coil packclio warning lights car with g aboveclio 182 emissions warning lightrenault premium warning light for fuelclio 182 liquid from exhaustclio car with G aboveclio 2.0 brake warning lightclio 182 exhaust emisions warning lightemissions warning light on renault cliorenault clio exhaust gas monitor warning light 182after driving through flood water renault clio 182 toxic light hasrenault clio 182 light came onexhaust gas warning light and hard to starthelp exhaust gas warning light and temp going up faster renault cliopetrol 182 clio sensorexhaust gas monitor renault cliorenault clio emissions warning lightexhaust monitor light clio 182 water coming from exhaust cliosport.net clio sport v power emissionsclio 182 coil warning lightclio 182 run on premium fuelclio emission warning lights diagram
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
