Page 27 of 29 FirstFirst ... 17 25 26 27 28 29 LastLast
Results 521 to 540 of 577
Thread: PH1 Flamer.
  1. #521
    Join Date
    Feb 2011
    Location
    Lowestoft
    Posts
    741
    Car
    ITB 428 Ph1
    Re: PH1 Flamer.
    £50 delivered if you want it bud
  2. #522
    Area Rep
    East Anglia
    Join Date
    Sep 2004
    Location
    Suffolk
    Posts
    10,771
    Car
    Monaco 172
    Yes you undo the two inside the TB and it all slides apart.
    I've also got an0ther one here which I can refurb and fit for £40
  3. #523
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,712
    Car
    421'd Monaco
    Re: PH1 Flamer.
    I will let you know cheers.
    The bolts on the inside are rounded!
  4. #524
    Area Rep
    East Anglia
    Join Date
    Sep 2004
    Location
    Suffolk
    Posts
    10,771
    Car
    Monaco 172
    Someone tried before or using a torx one size too small?
  5. #525
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,712
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Been out to play in the dark, both screws out using various methods. So the disc is now out of the throttle body, is that as far as it can be taken apart?
    And yes some had been at it before and failed.
  6. #526
    Area Rep
    East Anglia
    Join Date
    Sep 2004
    Location
    Suffolk
    Posts
    10,771
    Car
    Monaco 172
    Take the disc out and then pull the spindle bit out
  7. #527
    ClioSport Trader
    Join Date
    Aug 2011
    Location
    Bedford
    Posts
    5,723
    Car
    DON'T SEND ME PM'S!!
    Re: PH1 Flamer.
    I've got about 6 ph1/megane TBs. Have to mod the cable for the megane one, but if you don't improve your current one, they're there
  8. #528
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,712
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Cheers Dan but im getting one off DannyR tomorrow,
  9. #529
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,712
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Well after some persausion my throttle body was cleaned, previously the two bolts in side had been rounded off . Cleaning it seems to of done the trick, no more sitting at traffic lights with the the car revving itself!!
    Then i fitted the nimbus heatshield and removed the old bracket for the airbox.
    After doing that i got abit excited with the hole saw and swager (thanks to LewisTaylor for lending me this!) 18 holes late my car looks like this, was a pain to do with the radiator still in place
    The eagle eyed will notice a little screw in my wing, this is the key to holding my bumper on perfectly all the time!
    Then i actually washed, waxed and polished the car. Only to reveal 100's of scratches all over my car
    I have also come to the conclusion i need my air bag system resetting as no matter what i do the airbag light will not go off.
    Got Tax and insurance this month. And MOT next which it should pass. So there wont be much progress.
  10. #530
    Join Date
    Sep 2004
    Location
    West Lothian
    Posts
    7,348
    Car
    Clios + Panda 100hp
    Re: PH1 Flamer.
    Looks awesome! I hope mines looks half as good once I've started it.
  11. #531
    Join Date
    Nov 2009
    Location
    Norwich
    Posts
    2,419
    Car
    Trafic 140dci
    Re: PH1 Flamer.
    Engine bay looks awesome mate Much better now you've ditched that old carpet from behind the engine Might try your idea with that screw as mine hangs down a little there...
    You were very brave doing the whole sawing with the radiator still in lol.
    With regards to MOT i take it you know someone if you have your airbag light on?
    Also you need to unbolt your horns and bolt them on facing upwards
  12. #532
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,712
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Quote Originally Posted by Djw Dave View Post
    Quote Originally Posted by LewisTaylor View Post
    Cheers! The screws work well, my bumper hits things all the time and it's still holding tight.
    One day I will remember do move the horn! Lol.
    I was careful when drilling, it was tense at times.
    MOT I have 3 places that should do it no problem hopefully it will work out, I wouldn't mind getting it reset tbh just to clear the dash.
  13. #533
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,712
    Car
    421'd Monaco
    Re: PH1 Flamer.
    The cars being a complete pain atm, took the clio to my Dads work so i could get away from the rain. Purpose of the trip was to see where my exhaust was blowing from. Turned out to be from the cat.
    When laying under the car looking at it the right handside spring bolt is holding tension and the left is just hanging there. Tried to tighten it, then put washers on to give it more tension but still no good.
    Any ideas? Hoping i dont need a new cat fitting kit as its only done 1.5k.
    Few pics.
    On the drive home there's a nice stretch of road and the car was pulling all over the place. Also just before going to the ring my car was making a squeek noise when moving slowly.
    So Saturday i got some Lemforder lower ball joints and track rod ends. Hoping these would sort the problems, theyve also never been changed in 76k so cant do no harm
    After swearing and moaning they all got fitted (no pics). Just need to get the tracking redone.
    The bad news is it didnt stop my noise, but the car drives nicely now ill investigate the squeek some time.
  14. #534
    Join Date
    Jul 2011
    Location
    Nr Newmarket
    Posts
    1,630
    Car
    182 FF & PH1 172
    Re: PH1 Flamer.
    Glad you got the ball joints out in the end Dan
    Pretty sure you get a years warranty on them too
  15. #535
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,712
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Cheers was close to giving in.
    Depending on money I may order some poweflex anti roll bar things. If I do , do you fancy helping me fit them at weekend?
  16. #536
    Join Date
    Nov 2009
    Location
    Norwich
    Posts
    2,419
    Car
    Trafic 140dci
    Re: PH1 Flamer.
    Quote Originally Posted by Rhys Beal View Post
    Ball joints were a pain on mine, i was fortunate enough to have my car on a 2 post ramp to make life easier, wouldn't of wanted to do them off axel stands.
    My tracking needs doing badly atm too after changing track rod ends.
  17. #537
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,712
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Same, my wheels at like 10 o'clock direction when driving straight, i did measure the distances but obviously not very well
  18. #538
    Join Date
    Jul 2011
    Location
    Nr Newmarket
    Posts
    1,630
    Car
    182 FF & PH1 172
    Re: PH1 Flamer.
    Quote Originally Posted by dmallett View Post
    Sure, let me know a little in advanced when and I can either pop over or you could come to mine, whichever?
    They are a massive pita btw
  19. #539
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,712
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Track rod ends were dodgy couldn't get past 10mm of toe in. ECP gave me some more and they're fine new cat gasket and tracking getting done tomorrow.
    Running so much toe out atm the front tyres squeal round round abouts. Hope thats why anyway lol
  20. #540
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,712
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Spur of the moment thing, cup interior came up for sale under a mile from me and i knew my mate wanted my flocked dash.
    SO yesterday i ripped out the ph1 interior.
    Dash ready to be dumped,
    Then this morning i took some finished pictures of the fully wired in PH2 cup dash and front door cards just missing the steering surround which im getting at some point.
    Interior could do with a respray and its perfect imo. Also need to tidy a few wires and sort the heater controls out as they work different to the ph1, as in they go from 7oclock to 5oclock on the ph2 but 1oclock to 11oclock on the ph1 if that makes sense.
    Sprayed a few bits satin black also to match the wheels and interior,
    I apologies for the lack of pictures during the dash swap but tbh it was the last thing on my mind.
    Also insured the car fully comp for £790 for the year everything declared, happy days
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
clio sport ph1
clio 168 ph1
cupra splitter clio
ph1 flamer
site:cliosport.net ph1 clio project
what is a ph1 flamer
clio canister bleed
clio ph1 flamer rare
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
