Re: PH1 Flamer.
Standard suspension i do believe. Hopefully it will be lower soon
The gap should be the same as the front, looks ally high? Or are the tyres like a 45 profile?
Re: PH1 Flamer.
45 profile tyres. Ill be running 50's on them once the tyres are dead.
He may be getting some springs soon. As your my guru Danny, i take it springs off a ph1 will fit a 182 with cup packs?
Re: PH1 Flamer.
Originally Posted by
DannyR
The rear wheel gap will be big as that wheel is on the drop down for the drive, the other 3 are on higher ground.
(i'm judging your on about the last pic where the 182 looks like a 4x4)
Re: PH1 Flamer.
Fair point Lewis
i also had my camera with the lens twisted to 18mm, so it might be ever so slightly distorted also!
The springs will fit yes, red heights maybe a little bit different but not too bad.
45 tyres and the driveway are making it look high lol!
Re: PH1 Flamer.
Hey danny! Leave my bus alone!
lol
Re: PH1 Flamer.
No need to primer them Dan. Could you not get away with just rubbing them down rather than blasting them?
Luke-M
lol
Your gonna need to primer the wheels, especially if being blasted.
Re: PH1 Flamer.
Ill try rub them down, then see how it goes. Im not very good at prepping/painting stuff as im so impatient
Place in bury will sand blast 4 wheels for £80
JE finishing I think their called, there on barton road industrial estate
Re: PH1 Flamer.
Theres a blasting place next to my work, he wanted £80 to do Lewis's wheels, which i thought was steep. But i know nothing about blasting etc lol.
I may aswell give them to next door when the time comes then
Yea that's about the going rate then
Re: PH1 Flamer.
DannyR
I know. Although if they are only track wheels and you just rub them down well so fresh paint will stick well, a couple of top coats will be fine. Holds up for ages
Dan, blasting is time consuming, tedious and if not in a cabinet sooo messy so don't be too impatient! lol I spent a little while rubbing mine down and they come up good. So all mine stand me in is £15 per wheel and I removed all the curbing.
Re: PH1 Flamer.
I still can't believe that BIGASH can get sand blasted and powdercoated for £15 per wheel, so cheap. Would this not be a better idea? I'll probably be doing this if BA wheels norwich are anymore than £30 per wheel. As it will cost £60 to send to him and get them sent back (+ little more for beer tokens for James helping a mate out)
Re: PH1 Flamer.
Paisley Freight is cheapest that I know for couriering wheels
Re: PH1 Flamer.
Rhys Beal
Yeah £28 per set of wheels, i just rounded upto £60
Re: PH1 Flamer.
LewisTaylor
£25 mate
Re: PH1 Flamer.
Your girlfriend thinks my throttle bodies are pretty, that means it's permission to get them and it will impress her
Re: PH1 Flamer.
Haha. Typical female! One step at a time
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Visitors found this page by searching for:
clio sport ph1
clio 168 ph1
cupra splitter clio
ph1 flamer
site:cliosport.net ph1 clio project
what is a ph1 flamer
clio canister bleed
clio ph1 flamer rare
Powered by
vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules:
Sphinx-based search
