Page 6 of 29 FirstFirst ... 4 5 6 7 8 16 ... LastLast
Results 101 to 120 of 577
Thread: PH1 Flamer.
  1. #101
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,829
    Car
    421'd Monaco
    Re: PH1 Flamer.
    My dad just moved my car, it wouldnt hold revs in neutral and kept dropping until it would stall. It did this 3times then it held the revs at 500rpm and sounded rough as.
    Also the other day in the rain, when i put my foot on the brake it would illuminate the fog light light on the dash (if that makes sense) it wasnt fully lit but became visible, the car also started to drop revs. But was fine once i got going.
    Any idea what this is?
  2. #102
    Join Date
    Jun 2009
    Location
    Cymru!
    Posts
    1,356
    Car
    172 CUP
    Re: PH1 Flamer.
    Idle control valve?map sensor?
  3. #103
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,829
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Anyway of testing them to see if they are the problem?
  4. #104
    Join Date
    May 2009
    Location
    herts
    Posts
    684
    Car
    arctic blue 182
    Re: PH1 Flamer.
    this would be better than hammerite, and would look better i think
    http://www.halfords.com/webapp/wcs/s...egoryId_165495
  5. #105
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,829
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Quote Originally Posted by Matt e View Post
    Got a load of that beside me now, but the 500ml cans! its just prepping/doing it now.
    But im not allowed to work with my wrist, maybe get started Friday if i can
  6. #106
    Join Date
    Jun 2009
    Location
    Cymru!
    Posts
    1,356
    Car
    172 CUP
    Re: PH1 Flamer.
    Quote Originally Posted by dmallett View Post
    you can take the icv out and clean it and im sure you can put a mutilmeter across the map to see the readings from it.but im unsure what the readings should be
  7. #107
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,829
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Ill give it a try at some point cars not going anywhere for a few days anyway.
  8. #108
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,829
    Car
    421'd Monaco
    Re: PH1 Flamer.
    New 15mm rear spacers.
    And a k-tec sports cat. Which i got for £40
    Ill put it on at some point and see if it passed emissions tests, if so it was a bargin
    The car also seems to be running and idling fine now, hopefully it will stay this way.
  9. #109
    Forum User
    Join Date
    Mar 2010
    Location
    Cannock
    Posts
    171
    Car
    Ph1 & Ph2 172
    Re: PH1 Flamer.
    That's a right bargain mate car looks Lush btw,
    If u don't mind me asking how much did u pay for spacers ? Thanks
  10. #110
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,829
    Car
    421'd Monaco
    Re: PH1 Flamer.
    The rear were £50ish posted from motorsportsworld. Tbh i thought they would be hubcentrics like the front, but im not to bothered.
    The front were the same price as above but hubcentric.
    The 5mm ones were £55 posted, now for sale in the for sale section lol.
    The reason the delta mics are cheaper is because theyre made of steel or something.
  11. #111
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,829
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Fitted powerflex dogbone mount.
    Before
    Tools to remove old rubbers.
    After
    15mm rear spacers added.
    Front 25mm.
    And the whole car.
    Cars running like a bag of s**t, picking up another Idle control valve from DannyR at somepoint, hopefully that will fix it
  12. #112
    Join Date
    Nov 2009
    Location
    Norwich
    Posts
    2,419
    Car
    Trafic 140dci
    Re: PH1 Flamer.
    Those wheel's are spaced perfectly
  13. #113
    Join Date
    Aug 2006
    Location
    Suffolk
    Posts
    9,977
    Car
    Iceburg 172
    Re: PH1 Flamer.
    I tried the same rear spacers on mine and it rubbed constantly My s**tty springs don't help as the rear end just bounces everywhere! Got a set of FK 20mm fronts and 5mm rears arriving Monday, not alot more than Delta Mics but weigh alot less as they are alloy rather than steel. The delta mic 15mm's are hubcentric they just don't bolt to your disks, please make sure you don't use the bolts that come with them, they are made from cheese! A guy on here ran them and one snapped whilst driving.. I rounded one of mine when I used to run them on my old track car, replaced them with some ones off ebay just need to measure them up to replace.
    Looks great though mate, shame to hear its not running properly
  14. #114
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,829
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Cheers Lewis.
    And I am running the bolts, ill swap to studs all round soon. Just gota get new rear brakes first as one of the rear bearings is making noises, works out cheaper that way also.
    It will be running well soon hopefully!
  15. #115
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,829
    Car
    421'd Monaco
    Re: PH1 Flamer.
    I also have some pretty much new h&r 5mm spacers, you could've had cheap
  16. #116
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,829
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Got a idle control valve, £20 off my mates spare engine. hopfully it works.
  17. #117
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,829
    Car
    421'd Monaco
    Re: PH1 Flamer.
    Fitted new rear discs and pads as one of my bearings was shot. Whilst I was at it fitted some studs (with loctite) and some nice black nuts
    New front discs and pads thanks to Tom at West Renault, top service as always!
    New disc, studs and spacer.
    Front studs.
    Dirrty wheel with black nuts and locking wheel nuts.
    My jar of nuts/bolts/screw that ive collected since owning this.
    And a quick/bad picture of my spare wheel thrown on to see what it looks like.
    New front discs, pads and braided lines on the way also
    edit* Ive also fitted resistors so no more airbag lights, removed the rear arch liners as my wheel where eating them. Need to remove the carbon canister too and fix my bumper back on properly.
  18. #118
    Join Date
    Nov 2009
    Location
    Norwich
    Posts
    2,419
    Car
    Trafic 140dci
    Re: PH1 Flamer.
    Looks good mate, cant wait to get my stud & nut conversion as mine are rusty and look awful, I've done the same and kept a jar of all the nuts and bolts lol got loads from interior haha always comes in handy tho
    What disks and pads you got coming?
  19. #119
    Join Date
    Dec 2009
    Location
    Stowmarket.
    Posts
    3,829
    Car
    421'd Monaco
    Re: PH1 Flamer.
    DS2500s and brembo High Carbons. Im going to try get them on this week, probably in the dark lol.
    Never bled brakes so that could be on the only problem.
    And make sure you use loctite or something similar on the studs, otherwise you might just lose a wheel!
  20. #120
    Join Date
    Nov 2009
    Location
    Norwich
    Posts
    2,419
    Car
    Trafic 140dci
    Re: PH1 Flamer.
    Same as what i'm running, they are very good just careful with the front disk the t30 bolt can be a b@stard lol.
    It's fairly easy there is a guide on here, you will need someone else with you to pump the brake peddle tho.
    Yeah got some of that too haha.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
clio sport ph1
clio 168 ph1
cupra splitter clio
ph1 flamer
site:cliosport.net ph1 clio project
what is a ph1 flamer
clio canister bleed
clio ph1 flamer rare
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
