Re: PH1 Flamer.
My dad just moved my car, it wouldnt hold revs in neutral and kept dropping until it would stall. It did this 3times then it held the revs at 500rpm and sounded rough as.
Also the other day in the rain, when i put my foot on the brake it would illuminate the fog light light on the dash (if that makes sense) it wasnt fully lit but became visible, the car also started to drop revs. But was fine once i got going.
Any idea what this is?
Re: PH1 Flamer.
Idle control valve?map sensor?
Re: PH1 Flamer.
Anyway of testing them to see if they are the problem?
Re: PH1 Flamer.
this would be better than hammerite, and would look better i think
http://www.halfords.com/webapp/wcs/s...egoryId_165495
Re: PH1 Flamer.
Originally Posted by
Matt e
Got a load of that beside me now, but the 500ml cans! its just prepping/doing it now.
But im not allowed to work with my wrist, maybe get started Friday if i can
Re: PH1 Flamer.
dmallett
you can take the icv out and clean it and im sure you can put a mutilmeter across the map to see the readings from it.but im unsure what the readings should be
Re: PH1 Flamer.
Ill give it a try at some point
cars not going anywhere for a few days anyway.
Re: PH1 Flamer.
That's a right bargain mate
car looks Lush btw,
If u don't mind me asking how much did u pay for spacers ? Thanks
Re: PH1 Flamer.
The rear were £50ish posted from motorsportsworld. Tbh i thought they would be hubcentrics like the front, but im not to bothered.
The front were the same price as above but hubcentric.
The 5mm ones were £55 posted, now for sale in the for sale section lol.
The reason the delta mics are cheaper is because theyre made of steel or something.
Re: PH1 Flamer.
Those wheel's are spaced perfectly
Re: PH1 Flamer.
I tried the same rear spacers on mine and it rubbed constantly
My s**tty springs don't help as the rear end just bounces everywhere! Got a set of FK 20mm fronts and 5mm rears arriving Monday, not alot more than Delta Mics but weigh alot less as they are alloy rather than steel. The delta mic 15mm's are hubcentric they just don't bolt to your disks, please make sure you don't use the bolts that come with them, they are made from cheese! A guy on here ran them and one snapped whilst driving.. I rounded one of mine when I used to run them on my old track car, replaced them with some ones off ebay just need to measure them up to replace.
Looks great though mate, shame to hear its not running properly
Re: PH1 Flamer.
Cheers Lewis.
And I am running the bolts, ill swap to studs all round soon. Just gota get new rear brakes first as one of the rear bearings is making noises, works out cheaper that way also.
It will be running well soon hopefully!
Re: PH1 Flamer.
I also have some pretty much new h&r 5mm spacers, you could've had cheap
Re: PH1 Flamer.
Got a idle control valve, £20 off my mates spare engine. hopfully it works.
Re: PH1 Flamer.
Looks good mate, cant wait to get my stud & nut conversion as mine are rusty and look awful, I've done the same and kept a jar of all the nuts and bolts lol got loads from interior haha always comes in handy tho
What disks and pads you got coming?
Re: PH1 Flamer.
DS2500s and brembo High Carbons. Im going to try get them on this week, probably in the dark lol.
Never bled brakes so that could be on the only problem.
And make sure you use loctite or something similar on the studs, otherwise you might just lose a wheel!
Re: PH1 Flamer.
dmallett
Same as what i'm running, they are very good
just careful with the front disk the t30 bolt can be a b@stard lol.
It's fairly easy there is a guide on here, you will need someone else with you to pump the brake peddle tho.
Yeah got some of that too haha.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Visitors found this page by searching for:
clio sport ph1
clio 168 ph1
cupra splitter clio
ph1 flamer
site:cliosport.net ph1 clio project
what is a ph1 flamer
clio canister bleed
Powered by
vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules:
Sphinx-based search
