Page 3 of 3 FirstFirst 1 2 3
Results 41 to 54 of 54
  1. #41
    Forum User
    Join Date
    Nov 2006
    Location
    Manchester / Le Mans
    Posts
    3,567
    Car
    UB DCi 175
    Re: Sunroof Leak, Please HELP!!!
    Thats what i'll be doing temporarily until i get chance to sort it properly. it wont look that neat mind
  2. #42
    Forum User
    Join Date
    Feb 2008
    Location
    Thessaloniki Greece
    Posts
    253
    Car
    Clio MK2 1.4 16v
    how long is the piece of Mastic? Will one be enough or should i order two??
  3. #43
    Join Date
    Dec 2010
    Location
    Barnstaple, Devon
    Posts
    619
    Car
    clio 182
    Quote Originally Posted by l0rd View Post
    One is more than enough, it's best to stretch it out a bit as u go around else it will splurge out when it done up!!
  4. #44
    Forum User
    Join Date
    Feb 2008
    Location
    Thessaloniki Greece
    Posts
    253
    Car
    Clio MK2 1.4 16v
    Thank you for your reply.
    I would like to ask you one more question.
    Is the sunroof more than 2 pieces? The metal frame under the roof and the plastic frame which goes over the roof.
    What i have sone so far, is add some mastic near the drain plugs as i believe there is a gap on the plastic there as well.
  5. #45
    Join Date
    Dec 2010
    Location
    Barnstaple, Devon
    Posts
    619
    Car
    clio 182
    No those are supposed to be there, water is allowed to come through the seal around the glass, that is the purpose of the two drains in the corners. Yes the plastic part is the top part then the metal work of the car is sandwiched with the metal frame inside.
    The only place it will be leaking is between the plastic and the roof of the car, you can tell if it's loose by pushing around the sunroof and you will be able to move the tin work of the roof of the car up and down!
    Hope thatakes sence!? I really need to upload some pics when I next do one, which I think is Thursday!
  6. #46
    Forum User
    Join Date
    Feb 2008
    Location
    Thessaloniki Greece
    Posts
    253
    Car
    Clio MK2 1.4 16v
    Yes it does make sense.
    I will get a pic tomorrow to show what i have done so far.
  7. #47
    Join Date
    Dec 2010
    Location
    Barnstaple, Devon
    Posts
    619
    Car
    clio 182
    Haha I just read my last post back, my grammar is amazing!!!... Not!
    I blame my iPhone, yeah put some pics up and I'll do my best to help. I am very tempted to do a guide with pics, that way people can follow it alot better!
  8. #48
    Join Date
    Sep 2005
    Location
    Bristol
    Posts
    5,467
    Car
    meggy 285/197
    yeah do a guide im interested in this
  9. #49
    Forum User
    Join Date
    Jan 2012
    Posts
    4
    Car
    Renault Clio 1.2
    Thumbs up Re: Sunroof Leak, Please HELP!!!
    As a fellow clio driver and also a sunroof repairer i'd recommend visiting www.bettawindscreens.co.uk or searching them on google for all the information needed to solve all your problems. I would copy and paste but i don't want to be accused of stealing their information. :-) Good luck. A dry bum on the way to work is possible :-)
  10. #50
    Forum User
    Join Date
    Jan 2012
    Posts
    4
    Car
    Renault Clio 1.2
    Grease the hinges :-) both front and back
  11. #51
    Forum User
    Join Date
    Jan 2012
    Posts
    4
    Car
    Renault Clio 1.2
    Can i just say aswell don't use mastic. I repair sunroofs for a living and it is not advisable at all. It's just going to make it harder to repair in the long run and could mean paying for a new roof aswell as the repair.
  12. #52
    Forum User
    Join Date
    Jan 2012
    Posts
    4
    Car
    Renault Clio 1.2
    Quote Originally Posted by incy-spider View Post
    It's the Renault way - tried and tested about 50 times so far!!
    If it's the 'renault' way how come renualts leak. Obviously not that tried and tested seeing as theres a major issue with there roofs.
  13. #53
    Join Date
    Dec 2010
    Location
    Barnstaple, Devon
    Posts
    619
    Car
    clio 182
    Quote Originally Posted by CL10SAM View Post
    Haha very good! You can always trust someone to be ignorant on here!! Yes Renault Clio sun roofs are crap to start with but when fixed they will not leak ever again. The non Renault way or the silicone sealer way will cause issues!!
  14. #54
    Join Date
    Dec 2010
    Location
    Barnstaple, Devon
    Posts
    619
    Car
    clio 182
    The original foam seal is the problem, it's basically a piece of sticky back foam tape (think number plate sticky pads) this is not capable of sealing when the plastic roof frame is subject to expansion in hot weather, warpage and general movement of the chassis. The mastic we use is perfect for sorting the leaks as it allows for all the above to happen.
    Up to you what you do as a 'professional roof repairer' I'm only trying to help people by showing them the way it's been done for several years with not one come back dating back to the clio 1!!
Similar Threads
  1. Sunroof leak
    By Adam_S in forum Faults, Problems & Solutions
    Last Post: 20-02-2010, 18:49
  2. leak on the sunroof
    By ROB91 in forum Faults, Problems & Solutions
    Last Post: 05-12-2009, 22:42
  3. Sunroof leak:O
    By BenMc in forum Faults, Problems & Solutions
    Last Post: 18-07-2009, 10:24
  4. sunroof leak
    By jonny_g in forum Exterior & Bodywork
    Last Post: 05-03-2008, 21:44
  5. Sunroof leak!
    By Clellandmc in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 13-10-2005, 23:43
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
sunroof repairs devon
renault clio sunroof leak repair
leaking sunroof renault clio
how to stop clio sunroof from leaking
sunroof repair devon
renault clio sunroof leak scotland
renault clio leaking roof
renault clio extreme 1.2 54 plate leaking sun roof
renault clio sunroof drain
sunroof leaking on renault clio
how to fix leaking sunroof on renault clio
clio sunroof drain
renault clio mk2 sunroof seal
leaking sunroof on clio
how to fix a leaking sunroof on a renault clio
clio sunroof repair north east
buy renault clio sunroof seal
renault clio dynamique water coming from courtesy light vent
renault clio 53 leaking sunroof fix guide
sunroof repair south wales
clio sun roof repairs northwest
sunroof repairs north east
how to stop 03 clio sunroof leaking
clio electric sunroof leak repair
seal for electric sunroof on a 52 reg clio
clio mk2 sunroof leak fix
cliosport.net clio electric sunroof leak guide
mk2 clio seal for sun roof
renault clio sunroof leaking water
leaking clio sunroof
how do you stop a leak on a renault clio sunroof
photos of clio sunroof repair
fix leaking sunroof renault clio
sun roof seal 52 reg renault clio
how to fix leaking sunroof clio
renault clio sun roof leeks what can i useto stop thisrenault clio water leak sunroofrenault clio manual sunroof sealsleaking sunroof in clio local repairsclio roof 10mmclio sunroof leaking around handlehow to repair leaking sunroof on 01 renault clioclio sunroof loose boltssunroof water leak siliconrenault clio temporary sunroof repairaftermarket mk2 sunroof sealrenault clio sunshine roof leaksclio sliding roof problemsproblems with renault clio roof leak
