Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 60 of 77
  1. #41
    Re: FAO Mk1 F4R'd owners...Fault thread inside.
    Perfectly fine when warm? Tried another ICV?
  2. #42
    Join Date
    Jul 2005
    Posts
    32,284
    Car
    Lost Count
    Quote Originally Posted by f0xy View Post
    I haven't no. Not got another 172 in atm either.
    ffs.
  3. #43
    Mine used to stick/not open enough until the engine/inlet was hot, then it would be fine. Might not be the same thing, but its worth finding someone local with a 172 ph1 and giving it a try before buying anything I reckon..
  4. #44
    Join Date
    Jul 2005
    Posts
    32,284
    Car
    Lost Count
    Ok good man. I shall give that a bash (literally! lol) next week.
    I've got bigger fish to fry, its MOT time Friday....
  5. #45
    Lol, im sure it will `pass`!
  6. #46
    Join Date
    Jul 2005
    Posts
    32,284
    Car
    Lost Count
    Its going for a proper one. I told him I want it to be Proper council strict! lol.
    (apart from the emissions obviously..)
  7. #47
    Yeah, if its been looked after and it all works it should be fine to be honest - its just if there is any rust/rot it might be questioned etc..
  8. #48
    Join Date
    Jul 2005
    Posts
    32,284
    Car
    Lost Count
    Thats the bit that concerns me. Theres a fair bit.
  9. #49
    Join Date
    Jul 2005
    Posts
    32,284
    Car
    Lost Count
    Me again chaps!!
    Right, I seem to be eating driveshafts for fun atm. I fitted another secondhand one today and it lasted less than three miles before it started clunking its tits off again. I'm now on my 3rd n/s driveshaft.
    Whats causing this?? Is it possible that it could be too far into the gearbox??
    Cheers.
  10. #50
    Wierd, what shafts are they?
    Ive ran 172 Ph1, 172 Cup and some random 182 shaft on mine without issue in the past...
  11. #51
    Join Date
    Jul 2005
    Posts
    32,284
    Car
    Lost Count
    They've all been 172 Ph1 ones.
    Why did you change shafts so many times Jord?
  12. #52
    The first one was always f**ked due to the the thread for the hub nut being flatten'd on the end, so it was a pain in the arse to get the nut on.. So I got another, ran that for a while, had to remove the engine, took shaft out and dropped it on the end, thread f**ked on that one, so used my last spare and thats whats still on it now..
  13. #53
    Join Date
    Jul 2005
    Posts
    32,284
    Car
    Lost Count
    Ah I see.
    I'm starting to wonder if theres something else thats causing them to go, or if i've just been supplied with dodgy ones! lol.
    I don't really want to spunk £270 on a new one though if whatever the problem is is going to fcuk it.
  14. #54
    Forum User
    Join Date
    May 2004
    Location
    Bedford www.519automotive.co.uk Please Call DON'T TEXT, I HATE PM'd
    Posts
    9,439
    Car
    ITB'd MK1
    Quote Originally Posted by Daniel View Post
    what arms and hubs are you running?
  15. #55
    Join Date
    Jul 2005
    Posts
    32,284
    Car
    Lost Count
    The drivers side has a 172 Bottom Arm and a 172 Hub.
    The passenger side has a Williams Arm and a 172 Hub.
    (I bent the 172 bottom arm trying to undo the 30mm nut on the donor car. Used a 7 foot scaffold bar..... )
    The arms looked identical though so thats why I used the williams arm I had lying around.
  16. #56
    Williams and 172 wishbones are 100% definitely different, thats where the extra width with the 172 widetrack comes with when fitted to a Mk1 over Williams widetrack
  17. #57
    Forum User
    Join Date
    May 2004
    Location
    Posts
    9,439
    Car
    ITB'd MK1
    yep, there's your issue. you need an arm that matches the shaft you're using
  18. #58
    Join Date
    Jul 2005
    Posts
    32,284
    Car
    Lost Count
    Right, seems to be my downfall then! lol.
    We checked/measured/double checked/double measured EVERYTHING before we fitted it.
    So are we saying that i've spent £XXX on driveshafts when its the arm causing it to sit too far in and in actual fact theres nothing wrong with the driveshafts???
  19. #59
    Forum User
    Join Date
    May 2004
    Location
    Posts
    9,439
    Car
    ITB'd MK1
    more than likely
  20. #60
    Forum User
    Join Date
    May 2006
    Posts
    5,633
    Car
    BMW M5
    There was about 4mm difference in width from what I remember. I had the exact same problem when I originally put R19(williams) wishbones on mine, that's how we learnt theyre different.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
mk1 clio fan relay location
renault megane mk1 relays
renault clio immobilizer emulator
clio immobilizer bypass
mk1 f4r wont start
where is fuel relay renault megane
renault clio fuel pump relay
renault clio 57 reg main earth wire faults
clio ecu relay
renault clio 1.4 16v crank but wont start
can you put a f4r engine in to mk1
can i bypass petrol pump of 1.4 renault clio 2000
where do the wires go from fuel pump mk1 megane
renault megane immobilizer bypass
57 reg renault clio earth wire problems no electrics
f4r engine running rough
swap megane 1 motor f4r
rad in mk1 f4r clio
clio 1.4 earth strap
clio dci tacho wire
f4r engine gone sluggish
renault clio mk1 petrol pump wont work
clio 1.4 alternator relay
fault finder renault clio rt mk1
renault clio rt mk1 no start no noise blown fuse
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
