Old Black Bumper Trim - Spraying New Life Into It
I have bumper trim that has faded into a dull grey colour, and I want to spray it so it looks clean and fresh.
It has the dreaded pimple feel to the material. So a quick question, if I sprayed it over in black, would this be ok, or would it need to go through the works of sanding, prepping etc.
I am not bothered about it coming up smooth, but I want the finish to be good.
Thanks.
Re: Old Black Bumper Trim - Spraying New Life Into It
Dont need to bother spraying it if it is plastic?
If its plastic clean it back properly with some smooth peanut butter then use some trim restorer on it.
Or use WD40
as above, then something like AG bumper care i find good.
Originally Posted by
richy22
Or use WD40
Sorry for thread hijacking, but peanut butter?
Yes smooth peanut butter contains oils that break down any polish residue on the plastic.
Groundnut oil is actually what you should use but peanut butter contains this and is cheaper.
Then use some bumper care stuff and it will look as good as new.
If you spray it, IMO you need to prep it really really well to remove all the pimples, as it looks so sh*te if there left in and painted over the top. In the sun they just look GASH!
1. Prep so is smooth as a babies arse + some.
2. "Show it " a decent plastic primer..... (Show it, as in not coat it as its very thin and will run, just a very light coating)
3. Normal primer it
4. Light wet stand with 1500, being esp careful on the edges.
5. Base code (multiple coats until ur happy, leaving 15 mins between)
6. Dry over night.
7. Clear coat.
8. Flat if needed, and polish.
Or if in doubt, pop it off........post it and ill do it. For a fee of course
(I do tons of stuff at the moment, got the full setup for it.)
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Visitors found this page by searching for:
black bumper spray
spraying bumpers black
black bumper sign spary
spraying black plastic bumpers
black bumper spray kits
spray car bumoers blavk
spraying bumper trims black
old clio spraying oil
spray to re black car bumper
bummper black nspray
how to spray bumpers to look black
clio spray bumper black
how to spray trim on clio
blaxk bumper spray
sparying clio trim
how to use black bumper spray
spray black car trim
Powered by
vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules:
Sphinx-based search
