Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
  1. #21
    Re: Airbag + SERV Light after fitting steering wheel...
    as already said, check the resistors. check there fitted properly, doubled up to make contact with the sides of the connectors etc.
    it defo 100% will not be stored, and will go off when the resistors do the job.
  2. #22
    Forum User
    Join Date
    Jun 2003
    Location
    Suffolk
    Posts
    10,693
    Car
    Bumder With A Buffer
    Quote Originally Posted by SteveS Cup View Post
    Are they definitely 3.3ohms?
    The ones k tec sent me are 1.8. The nearest we've got is 2.7 so I'll have to shoot into maplins to get some 3.3's. What if I used 4.5ohms?
    Try the 2.7 ones if not Replace with 3r3 or 3r9 and all will be sorted.
    In theory anything from about 2-6 should work but it depends what tolerance the 1.8 ones are I.e 10% on 1.8 means it could be as low as 1.6 ohms.
    Everyone who has had issues has replaced with 3.3 or 3.9 and things have been fine. Try your 2.7 ones first though as I have just popped outside and tried it on my seat one and it worked fine
  3. #23
    i think im using the 3.3ohm ones. just grabbed a selection from maplin when i first did mine. cut up and used the spares as packer peices to make sure they were secure in the connectors.
  4. #24
    Join Date
    Mar 2009
    Location
    Co. Durham
    Posts
    4,004
    Car
    182
    Should be like this mate
  5. #25
    Forum User
    Join Date
    Jan 2010
    Location
    Dorking, Surrey.
    Posts
    1,855
    Car
    Iceberg 172
    Yeah that's cool. I've just gone to maplins to get some 3.3 ohm resistors so I'll fit them later and clear the fault codes again and see what happens. If that doesn't work I'll use some 4/5 ohm ones.
    Thanks for all your help guys.
  6. #26
    Join Date
    Sep 2008
    Location
    Chester
    Posts
    1,119
    Car
    Clio RS 172 /Trafic
    My Nissan Primastar had to have resistors fitted in the rear when they did the conversion from minibus to hackney spec taxi. It used to have rear airbags from the factory but they remove them because they fit different rear seats and belts.
    I've just had to have the resistors replaced as one of them was turning the airbag fault light on all the time.
    Wondering whether to get them to fit a resistor to the clio when I get round to replacing the wheel.
  7. #27
    Join Date
    Aug 2004
    Location
    Cheshire
    Posts
    15,822
    Car
    Should be broken
    Quote Originally Posted by Tom@JMS View Post
    Could be a multitude of things you have done wrong mate, but those lights will need a Renault System to turn off I believe, even our Snapon Ethos won't do it.
    Quote Originally Posted by Da View Post
    It's because you switched the car on before fitting the resistors at a guess, the airbag missing fault will now be stored as Tom said above.
    Wrong. The circuit will clear the fault light once the right resistance is seen. No reset code readers or what not needed.So you either have the wrong resistors, or a bad connection.
    Any resistor between 2 and 6 ohms will work.
  8. #28
    Forum User
    Join Date
    Jan 2010
    Location
    Dorking, Surrey.
    Posts
    1,855
    Car
    Iceberg 172
    What a nightmare!
    I have no idea how but my mate has the full on diagnostic equipment and he's managed to turn off the 2 front airbag circuits thus meaning no lights!!! Whoop whoop!
    There's no resistors being used!!! Don't ask me how as I have no idea!!
    Thank you to everyone who helped, I'm now over the moon with it!
  9. #29
    Join Date
    Aug 2004
    Location
    Cheshire
    Posts
    15,822
    Car
    Should be broken
    You can with either Clip (Renaults stuff) or some decent 3rd party equipment.
  10. #30
    Forum User
    Join Date
    May 2004
    Location
    NW
    Posts
    15,403
    Car
    Less
    Surely with the circuits turned off though, the pretensioners would be inoperative too?
  11. #31
    Forum User
    Join Date
    Jan 2010
    Location
    Dorking, Surrey.
    Posts
    1,855
    Car
    Iceberg 172
    nah, it's just the 2 drivers airbag circuit that has been turned off... there was loads of different circuits for the pretensioners / passenger airbag etc.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
Vaux movano 2008 fault code df003
nissan primastar service light reset
airbag light on nissan primastar van
vivaro fault code df003
renault traffic df003
nissan primastar service light and airbag light on
nissan primastar airbag warning light
air bag module primastar
how to remove a steering wheel on a nissan primastar
df003 nissan
primastar air bag fault
df003 renault traffic fault code
Trafic df003 code srs
df003 renault airbag
turn off service light nissan primastar
primaster nissan streering wheel removalprimastar airbag fault fixdoes primastar have airbag relaynissan primastar serv light onairbag lampa primastarrenault traffic airbag fault code df003how to get the air bag light off on nissan primastarreset nissan primastar service lightnissan primastar sport steering wheelhow to remove airbeg primastarprimastar steering wheel airbagdf003 airbag code renaultdf003 renault airbag fault codedtc df003renault code DF003renault traffic air bag fault line 2renault master airbag df003airbag light on movanorenault trafic air bag ringrenault df003airbag fuse movanomovano air bag lightkasowanie poduszek nissan primastarrenault traffic airbag fault codesnissan primastar airbag lightrenault trafic aibag code df003traffic airbag fault code df003what resistor goes in renault master air bag lighthow to turn off airbag light after remove clio steering wheelnissan primastar varningslampor lyser site:cliosport.net clio sport fitting steering wheelhow to remove fault codes on nissan primastarnissan primastar airbag and serv lightnissan primastar 2004 service light reset2008 renault trafic fault code df003
