Results 1 to 7 of 7
  1. #1
    Archived Post from old forum
    I had my valvers cambelt changed about 7,500 miles ago, the water pump and alternator belt where both changed too.
    Been running fine for the last 7,500 miles but now when I start her up from cold I get this horrible squeeling noise coming from the cambelt cover, when I rev her it stops. Doesnt seem to do it when its up to temp. Also it sometimes seems to idle at arounf 600rpm.
    Anyone got any ideas whats going on? And what should I do?
    Cheers, Simon
  2. #2
    Forum User
    Join Date
    Jul 2002
    Location
    Seinajoki, FINLAND
    Posts
    610
    Car
    Williams 2, STi N12
    Could be the bearings on the pully tensioners, they have a nasty habbit of going. Does it only do it when you reach a certain rpm?
  3. #3
    Only seems to do it when it either idling or at low rpm, soon as you rev it it shuts up.
    Are the bearings hard to replace?
    Cheers, Simon
  4. #4
    sounds like the altinator belt or the cam belt tentioners
  5. #5
    Forum User
    Join Date
    Jul 2002
    Location
    Seinajoki, FINLAND
    Posts
    610
    Car
    Williams 2, STi N12
    Not a b**ch to replace on there own but to do it you have to take the cambelt of again and go through all that crap. You sure the altenator belt isnt slippin?
  6. #6
    Forum User
    Join Date
    Jan 2002
    Location
    wigan
    Posts
    11,368
    could be its just loosened up a bit as a new belt will. just needs a wee tightning
  7. #7
    Join Date
    Aug 2002
    Location
    sheffield
    Posts
    4,367
    Car
    clio williams, Ph1 172
    Since I had my cam belt change I get a bit of a whiring noise from the engine. It was changed ages ago now. the car runs great but just wondered if anyone knows what it is. Is the belt too tight?
Similar Threads
  1. Please help identify this noise (video)
    By ScarySquirrel in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 15-04-2010, 16:48
  2. HELP, whats this?
    By DrRollo in forum Faults, Problems & Solutions
    Last Post: 18-06-2008, 21:13
  3. Whats This Noise (vid)
    By nth in forum Faults, Problems & Solutions
    Last Post: 30-03-2008, 16:16
  4. Whats this noise?
    By clio-16-valver in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 15-12-2005, 12:15
  5. Help...Whats this warning light mean
    By chris172 in forum Clio Discussion
    Last Post: 07-10-2004, 22:28
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
Nobody has landed on this page from an internet search engine.
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
