Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 81 to 100 of 109
  1. #81
    Join Date
    Sep 2004
    Location
    Wantage, Oxfordshire
    Posts
    261
    Car
    RB 182
    Re: Different Suspension Setups on All Models
    Quote Originally Posted by Fastdanbar View Post
    anyone got pics of the new more expensice Spax the 519 sell??
    I have these fitted but dont have any photos yet, I can say though that the ride is much nicer than the gaz ones I had previously and still feel nice in the bends will get some photos up when I get a chance.
  2. #82
    South West
    Join Date
    Mar 2010
    Location
    Helston Cornwall
    Posts
    2,789
    Car
    Yozza'd Blue Bus
    Quote Originally Posted by Joah View Post
    thank you
    would you say it has better feel with this setup?? and also does it compare to standard cup setup??
  3. #83
    They are a deffinate improvement over the std cup setup (I had std shocks with eibach proline on), and with the spax setup is both sharper to drive and rides better.
    They do appear to be a nice setup.
    thank you
  4. #84
    Join Date
    Sep 2004
    Location
    Posts
    261
    Car
    RB 182
    thank you
    I never drove mine with standard setup, but these feel 10x better than the crashy Gaz ones that were on there before.
  5. #85
    South West
    Join Date
    Mar 2010
    Location
    Helston Cornwall
    Posts
    2,789
    Car
    Yozza'd Blue Bus
    Quote Originally Posted by charlesk View Post
    thats good then its gonna be hard choice for me picking between the B14s and the Spax :s
    and thats good to hear too as i went in a 172 cup with an expensive GAZ setup and it was really horrible tbh
  6. #86
    Join Date
    Sep 2005
    Posts
    3,849
    Car
    172
    Quote Originally Posted by f0xy View Post
    coilovers with custom rear springs, 16' wheels, 45 profile tyres, around 100mm...
    some other custom rear springs, rest same as above, more than 100mm...
    EPIC car is EPIC
    (well done that man even if you have no teeth left of unbroken bones in your spine !)
  7. #87
    Join Date
    Jan 2011
    Location
    Chester
    Posts
    4,961
    Car
    RS2'd RB182
    Jason = Hero??
  8. #88
    Join Date
    Nov 2011
    Posts
    2,102
    Car
    Clio 172
    Hi Guys, Is there a good shock and spring setup for a ph1 172 without going to coilovers or am I best sticking to standard and then getting something like the spax 519's? The car has been bought to be mainly run as a track toy so I am only really concentrating on good tyres which are sorted, brakes which are done or on their way in the post to me and suspension. If I get the braking and handling right I'll be fast enough. SO just need your views if there is anything better than the standard suspension that won't cost me £800.
  9. #89
    ClioSport Trader
    Join Date
    Aug 2011
    Location
    Bedford
    Posts
    5,706
    Car
    DON'T SEND ME PM'S!!
    Quote Originally Posted by 2Damnsly View Post
    you'd be looking at around £500 for a good shock and spring combo.
    The £699 spax option is very much well worth considering still
  10. #90
    Join Date
    Nov 2011
    Posts
    2,102
    Car
    Clio 172
    What about going down a new set of cup shocks and eibach springs route?
  11. #91
    ClioSport Trader
    Join Date
    Aug 2011
    Location
    Bedford
    Posts
    5,706
    Car
    it's valid. Personal taste if you like them really. I do have a number of people mentioning they're not different to standard by any moticable margin which they're disappointed with
  12. #92
    Join Date
    Nov 2011
    Posts
    2,102
    Car
    Clio 172
    Quote Originally Posted by 519 Automotive View Post
    Thanks for the response, I think I'll get the rear lower arb, maybe front and rear upper (not sure the difference they will make) and sort the brakes and then worry about the suspension later.
  13. #93
    Clio mk3 07 plate 1.2 got apex lowering springs 30mm but compressed another 30mm, ordered Koni sport dampers, anyone know some decent after
    Market brakes?
  14. #94
    Join Date
    Nov 2011
    Posts
    2,102
    Car
    Clio 172
    Juwa the brake combo most people run with are standard rears and HC Brembo front discs and DS2500/DS3000 pads.
  15. #95
    Forum User
    Join Date
    Jan 2012
    Location
    Bham
    Posts
    8
    Car
    Clio mk2
    ello mate, have u got 17" alloys? if so thats what i was going to get for my clio but didnt kno whether id need lowering springs or not, the gap you have is what id want and there standard springs arent they? - Rich
  16. #96
    Forum User
    Join Date
    Feb 2012
    Location
    Huntingdon, Cambs
    Posts
    6
    Car
    172 Cup
    Rather than bothering with ride height, does anyone have spring rate specs of these aftermarket springs?
    What I'm wanting to know is-
    172cup spring rate
    182 cup spring rate
    172/182 Eibach Pro kit spring rate
    172/182 Eibach Sportline spring rate
    172/182 Apex spring rate
    172/182 Koni Spring rate
    I just need the spring rates, I can work out the ride height drops from that and any geometry changes that may occur.
    Incase this wasn't known info, Eibach Pro Kit springs are designed to offer a slight ride height reduction, slight increase in spring rate, and most importantly, work with the OEM dampers.
    The Sportline kit increases the ride height drop with a similar spring rate, but should really be used with shortened dampers.
    Infact, any ride height drop of more than about 35/40mm should normally be accompanied by shorter dampers.
    I use the term damper and not shock absorber because technically, a spring is a shock absorber, dampers are there to dissipate the energy from the shock/spring.
  17. #97
    Forum User
    Join Date
    Apr 2011
    Location
    Bangor, Wales
    Posts
    2
    Car
    ClioSport 172 :)
    Hi. Im just waiting for my clio 172 to come back from the garage which is a £800 bill! Id like some advice on which spring to buy that will lower my car quite abit....coilovers costs around £350 and thats too much. Iv only seen springs that lower 40mm.....
  18. #98
    Forum User
    Join Date
    Mar 2010
    Location
    Watford
    Posts
    1,271
    Car
    It's a clio
    Quote Originally Posted by dewibull View Post
    Any lower on springs then 40 you'll ruin your shocks. Get either sportlines for ride or apex for looks. If you want to go low then coilovers it is.
  19. #99
    Forum User
    Join Date
    May 2012
    Posts
    36
    Car
    Clio 182 cup +3
    Quote Originally Posted by str160 View Post
    172cup spring rate
    182 cup spring rate
    here here lol! I agree with the damper/ shock absorber terminology. I'm a MOT tester and even on the computer it (wrongly) refers to "leaking shock absorbers" .I find it quite irritating. I cant help you with the spring rates I'm sure the manufacture website must have it somewhere buddy
  20. #100
    Forum User
    Join Date
    Oct 2012
    Posts
    1
    Car
    2005 impreza turbo
    Hi guys which are the best/common coilovers to use for track only?
    regards
Similar Threads
  1. Bulb Fitment - All models (Mk1,2,3)
    By donsrno1 in forum Interior, ICE, Security, Lighting & Electrical
    Last Post: 24-07-2008, 09:46
  2. Parts Catalogues wanted - Clio's all models.
    By AliasOmega in forum Clio Discussion
    Last Post: 12-08-2007, 22:45
  3. What suspension do you all recommend!
    By C8DGY in forum Engine, Gearbox, Exhausts & Running Gear
    Last Post: 21-01-2007, 03:23
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Visitors found this page by searching for:
clio gt tuning
renault clio lowered 60mm
clio lowering springs
clio 172 cup gold alloys whitby
bilstein b14 clio 3
suspension low clio ph2
suspension clio ph2
clio ph2
clio sport ph1
clio gt lowered
mk3 clio coilovers
bilstein b14 clio c
clio gt 2010
mk3 renault clio lowered 60mm
clio mk3 on 60mm
clio gt
mk3 clio lowered 70mm
eibach sportlines clio 182
clio 172 lowering springs advice
clio sport 172 suspension
182 before and after on sportlines
LOWERING SPRINGS 40mm clio
clio with 40mm lowering springs
40mm clio lowering springs
clio sport 172 blue
lowered clio 40mm
clio 172 sport gold
clio gt france motorsport
photo of 40mm springs
mcpherson suspension clio 172
2011 Clio suspension high
clio 2 ph2 race
site:cliosport.net clio 172 cup apex
coilover clio 3
clio apex 60mm
clio mk3 lowering 40mm
clio sport ph2 cup 182
clio 172 ktec coilovers
clio 182 with eibach pro
clio 40mm lowering springs
clio 172 apex springs
clio gt rims
new renault clio 1.4 lowered 60mm
clio on fk suspension
clio spax coilovers
clio 172 lowering springlowered clio gtmk 2 clio 35mm loweredclio ph2 1.2
Powered by vBulletin® Version 4.1.10
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright © 2000 - 2012 ClioSport Ltd. Company No. 08149668
Digital Point modules: Sphinx-based search
